Reply
Problem setting up WGR614v10, can't login to routerlogin.net
I bought a WGR614v10 recently and have been unsuccessful in setting it up using either the Netgear CD or via browser.
If i run the Netgear smart wizard, it shows me the error 'No Router' after the Cable Verifications step, although i can very well access internet through LAN, and even connect to the connection with the default SSID, but i still do want to change it.
I also can't log on to www.routerlogin.net, every time I try to open it, i just get the error Oops! Google Chrome cannot find www.routerlogin.net (tried with routerlogin.com, and still the same thing.)
on ipconfig/all i get the default gateway 10.0.0.1
I try to open that, it redirects to routerlogin.com and then again Oops! Google Chrome cannot find www.routerlogin.com
I've tried resetting it, but nothing seems to work Smiley Sad
Luminary
Re: Problem setting up WGR614v10, can't login to routerlogin.net
see router setup on my sig below.. already answered your mistakes
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
I followed your tutorial, and finally i am at least able to get to Smart Wizard, but even so I cannot connect
Here's a screenshot of the router status
Luminary
DSL modem/gateway must be in bridge mode
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 3 replies
  • 7210 views
  • 0 kudos
  • 2 in conversation
Top Contributors
