Reply
Tutor
Problem to connect on www.routerlogin.net or http://192.168.1.1
Hello folks recently I got problem with my router WNR854T, any attempt to connect to the router with http://192.168.0.1 (or http://192.168.1.1) takes a long time trying to connect and then the connection times out. Same with www.routerlogin.net, and www.routerlogin.com. I have newest firmware version 1.4.22, windows XP Professional and I using Wn121t wireless. I tray to reset router and do settings again but it didn't help.
Anyone know how to fix this problem or why this is happining.
Tutor
Re: Problem to connect on www.routerlogin.net or http://192.168.1.1
what does
ipconfig /all
say
do you have norton firewall, or any software fw?
can you
ping www.routerlogin.com
Tutor
I have Panda Internet Security 2008 but if I disable protection or firewall sutuation is same...
Pinging www.routerlogin.com [192.168.1.1] with 32 bytes of data:
Reply from 192.168.1.1: bytes=32 time=16ms TTL=64
Reply from 192.168.1.1: bytes=32 time=17ms TTL=64
Reply from 192.168.1.1: bytes=32 time=14ms TTL=64
Ping statistics for 192.168.1.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 14ms, Maximum = 17ms, Average = 15ms
Have you been able to connect to the internet? I had the same problem, my modem was using the same IP as the router. I changed the router IP adress and all is fine.
Tutor
yes Im able to connect on internet and router is connect directly on internet.
Alexv when you set your router up at that point did you have to assign it a different IP adress? Factor Ip is 192.168.1.1 i believe and so are most modems. The router will reassign itself a new IP adress. It should of asked if you wanted to print that page showing you what all your settings were. IP adress, login password ect..
Also you can only get to the router login page with the computer that the router is wired to. Example if the router is connected to a desk top and you are trying to access it wirelessly from a laptop it will not let you.
Also you can reset the router again and see if it assigns itself a different IP adress.
Try this IP address first. 10.0.0.1 and see if it gets you to the router login
Virtuoso
I am not aware of any router function that asks if the user wants to print a page of settings, where do you see this?
The router does not assign itself an IP address, the DHCP server allocates IP addresses, and so resetting the router will not necessarily result in a different IP address. The modem may act as a DHCP server on the WAN side, and the router is a DHCP server for the LAN side.
It does not matter if the computer configuring the router is wired or wireless, but only one computer can configure the router at a time, in switching from one to the other you need to remember to log out of the router configuration to allow the other computer to log in.
Where are you suggesting that the IP address 10.0.0.1 is entered?
yeah so im having the same issue.ive tried i dont know how many timesSmiley Sad.all i want to do is config the firewall so my system is that more secure.
Luminary
too vague to answer
first see "Router setup" on my sig below and make sure your setup is okay between broadband and router
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
having trouble using setting it up
Luminary
Detail the issues wot model include
Do not hijack thread either if wnr854t
http://forum1.netgear.com/forumdisplay.php?f=31
Above is for wireless router categories
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
i have 2 computers. one is hard wired to the router and the other is wireless and both work great. i cant get my cell phones to connect to the wifi provided by the netgear router. i have tried 3 different phones so the phone is not the problem. is there something that i need to do to make the wifi available to my phones as well??? i thank you so much!!!
Novice
I cannot connect to my router all the lights are on. I've reset it countless amount of times. all the proper lights are suppose to be on I don't know what to do
Luminary
Router is brick. You need to replace the router
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 13 replies
  • 892141 views
  • 8 kudos
  • 9 in conversation
Top Contributors
