Reply
Novice
[Question] How to Block Specific Sites on a Guest Network (Netgear WNDR3700)?
Hi Everyone,
I have a Netgear WNDR3700 (Firmware: V1.0.4.66). I believe it's V1 since it doesn't say anything on the router after the model. I have already setup a Wireless network for our home. However, after setting up the Guest network with a WEP key I want to BLOCK specific sites.
For example, if it's a computer on my Wireless network it should be able to to access Netflix, PornHub, etc. But if it's on my Guest Network it should be BLOCKED. Is this possible?
When I go to Attached Devices in the side panel - the page comes up blank. Under "BLOCK SITES" http://i.imgur.com/aPRiXdE.png
I want to trust more than 1 IP address (we have 4 desktops) and two Guests staying for the month. Please let me know if I can provide any additional information.
tl;dr: Once a User is connected to the Guest Network how do I block specific sites? Thank you!
Luminary
Re: [Question] How to Block Specific Sites on a Guest Network (Netgear WNDR3700)?
Keyword will be effected on primary and guest wireless
It will only allow single ip for trusted
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Retired_Member
No ...None needed ...you can't
Novice
Thanks! You have helped me about three years ago! I remember you, just wanted to say to a quick thank you!
Also, could you recommend another router that can? Is there any other way I could open restrictions for trusted laptops/desktops in my house but control the websites my Guests are surfing around?
Novice
Ah! None needed? What do you mean?
Luminary
You need better to have hotspot wifi products like open-mesh AP unit and use opendns in their portal and use their free filtering.
Unless you want both primary and guest to have same filtering
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Luminary
probably mean you can't do what you want..
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Novice
Could you recommend a router that could do this?
Luminary
open-mesh.com
You can run guest easily as well
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Retired_Member
Yes thanks... "none needed" meant no more information was needed.
Discussion Stats
  • 9 replies
  • 3354 views
  • 0 kudos
  • 3 in conversation
Top Contributors
