Reply
Remote Home Surveillance Cameras Monitoring not working
Hello. I have a DVR and cameras setup at home. I want to view them on my Iphone5, but can't. I can log in with other computers that are connected to the router, but when I try the wireless, etc on phone, says error. Im thinking Comcast/Netgear is blocking port 80? I try to log in with the comcast IP and supposed to forward to the DVR cameras/DVR IP which is 192.168.1.5. Anyone have the same problem? Here is the link for the Comcast post:
http://forums.comcast.com/t5/Home-Networking-Router-WiFi/Remote-Home-Surveillance-Cameras-Monitoring...
Darren
Netgear N600, WNDR3400
Luminary
Re: Remote Home Surveillance Cameras Monitoring not working
http://customer.comcast.com/help-and-support/internet/list-of-blocked-ports/
Which cable modem model do yo use?
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
I have the Arris. My 2 other computers in living room can see the cams, except Iphone5. Smiley Sad
Prodigy
Rodog - if you're using the iphone on wifi you MAY be able to access the DVR via it's web interface on port 80. Please note I said MAY, if you had to download/install an activex control the first time you connected, it won't work on the iphone. If you're using the iphone via your cellular provider the following questions need to be answered or steps taken where necessary.
Cut and paste directly out of your other thread.
fordem wrote:
1) What port(s) does the DVR require?
2) Have you forwarded those port(s) in the router?
3) Have you configured those port(s) in mobileviewer2?
For what it's worth, although the DVR may allow web monitoring on port 80, I don't think that's the port mobileviewer will be using, that will more likely to be something in the 9000 range, I'm using the Android version of mobileviewer with port 9010.
June - all you're doing is confusing the issue and cluttering the forum with duplicate threads - my temptation is to lock this one and force the discussion back to the original thread.
Give a man a fish, feed him for a day
Teach a man to fish, feed him for life.
Luminary
It's not confusing people. When you reply to thread with answer instead of ell user to go right correction makes any user visit the site to post ANYWHERE.
If you don't guide it you loose it. Simply as that... It's now posted on right place and do not need to be discussing this
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Luminary
I have the Arris.
what is the actual model#.....
My 2 other computers in living room can see the cams, except Iphone5. :
This could be lead to the first question I have.....
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Actually June, I cant understand your English.
So far, nothing is working. On the LAN, (ex: http://192.168.1.5:9000) everything is fine, but the iphone5. If anyone needs my email address, it would be better if some1 knows what's going on. Im starting to think the DVR is messed up, its one of those cheap models from ebay, but the LAN works, so I don't know. Port forwarding is set to 80 ---> 192.168.1.5:9000
Luminary
If you are going to use 9000 then DVR must set to use 9000
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Arris Model WBM760A.....
Luminary
Arris is just cable modem so..
this still applies..
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Trying to post pics, but keeps wanting a url. My Comcast post with pictures. The port was 80 at the time, now 9000...
Luminary
if DVR was 80 then 9000 will have never worked.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Im thinking its a router issue that I must be overlooking. LAN is fine, Iphone5 no. Ive also reset router. Still working on it. Smiley Sad
Luminary
If DVR is set to 80 and Forwarding set to 9000 will not work
Your screenshot from other site shows 80 on DVR settings
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Prodigy
Are you trying to access the DVR from the iPhone via the Wifi network or the mobile network?
If it's via WiFi, the router plays no part. If it's via the mobile network, it's a possibility.
Your best bet would be to get it working via WiFi (to eliminate the router & ISP as a possible problem area) and then take it to the next level.
Well I bought a new system from Costco, and same thing. Even their software set up the router and still same thing. Must be the Iphone5. I can watch it on the LAN and wireless laptop.
Luminary
Are you certain that you have ports 9000 is setup on DVR?
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
yes, everything set. Im thinking maybe router, or Iphone5 not compatible. Cant add pictures, says it wants URL. This is starting to get annoying too.
Router Port Forwarding:
http port 3900 ---> port 3900 on dvr on 192.168.001.002
client port 9000 ---> port 9000 on dvr on 192.168.001.002
mobile port 1025 ---> port 1025 on dvr on 192.168.001.002
DVR:
Type - DHCP
Client Port - 9000
Mobile Port - 1025
Static IP - 192.168.001.002
Subnet Mask - 255.255.255.000
Gateway - 192.168.001.001
DNS1 - 192.168.001.001
DNS2 - 000.000.000.000
Auto Port Forwarding - Enable
Also, do I have to log in with admin or can I use another user I created?
Posts should be instantly posted so we don't have to wait hours to see them.
I also did a port scan on port 80 and said it was closed, wondering if that could be a problem, since that's the web port.
Luminary
Forum go though approval process so this will not change it
If the port 80 is not open in forwarding then it will see as close
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Luminary
DVR:
Type - DHCP
Client Port - 9000
Mobile Port - 1025
3900.. what is this?
I see 9000, 1025 ports in DVR settings
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
That's how lorex set it up, and says to do that. :confused:
UPDATED Router Port Forwarding:
WEB HTTP port 4000 ---> port 4000 on dvr on 192.168.001.002 (Default 80)
DVR:
Type - DHCP
Client Port - 9000
Mobile Port - 1025
LAN and Wireless Laptop work perfect, now its just Iphone5.
And the problem is ????
Iphone5 and iOS6
I had that feeling. My friend logged in from his house on the internet and he could see the cams. So the problem is iOS6. Now we need an APP that will work, maybe some1 will soon. Thanks for all the help.
Prodigy
The fact that your friend can login proves ONLY that remote access is possible, which was never in doubt, you haven't told us what your friend is using, presumably a PC, which does not use the same ports as the iPhone would.
You want an app that works - try MobileViewer - make sure you get the correct one for your iPhone, and make sure you configure the router to forward the correct ports.
Luminary
Iphone5 and iOS6
So so how are you accessing DVR with iPhone
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 50 replies
  • 9691 views
  • 0 kudos
  • 4 in conversation
Top Contributors
