Reply
Repeater WGR614v9 and Dlink WBR-1310
Hi,
I'm quite a newb when it comes to routers. My roommate has a WGR614v9, currently not connected, that she has no clue about how it was set up before. I have a Dlink WBR-1310 which is currently running as our wifi network. I was wondering if I can use her router as a repeater or vice versa - connect hers to the Ethernet and use mine as a repeater?
Any help will be greatly appreciated.
Thank you
Luminary
Re: Repeater WGR614v9 and Dlink WBR-1310
repeating is possible on V9 of the router but you will compromise the encryption down to WEP or None so I would say ditch the idea if you are thinking about wirelessly connecting these two together.
only other way is to use ethernet cable each other
http://kb.netgear.com/app/answers/detail/a_id/965
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
I believe it is currently set as WEP.... I'm guessing from the way you wrote about it that it is a very low level of security? Are there any router that allow repeating and a higher level of security?
Let me ask you something else if you don't mind:
Will it be easier to use the same type of router (basically buying two of the same type) if I wish to use one as a repeater?
If it is, then which one allows repeating from these: Linksys E1000, Belkin N150 Wireless N Router, and D-Link DIR-601 Wireless N 150
Thanks again!
Luminary
you best choice is WN2000RPT, WN3000, WNCE2001 extender which will give you use higher encryption
WEP are hackable 100%, I would avoid that if you can use ex. WPA2 with current wifi devices on your router before about repeating. if you can the above model works well for you
across the border , all manufacture do use WEP for repeating 9/10
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Excellent advice.
What about using that "DD-WRT" thing with a decent router? Will that increase my range significantly?
Luminary
if you have compatible router you can explore better firmware but not necessary makes range dramatically better
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
What about does huge antennas?
or this - http://www.firefold.com/TP-LINK-WA730RE-150Mbps-Wireless-Range-Extender-P31019.aspx?afid=67&gclid=CO...
Luminary
you are asking thing you need to try and error
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Ok... I will either buy and antenna or go for the suggestion you made with using it as an access point and running a wire to my dlink.
I will need the wire to run for about 25ft....
Is it a standard ethernet wire?
Where can I get a wire like that for cheap?
can I cut one and re plug it?
Luminary
yes..
you can try go to local computer shop to make you one but I would get pre-make cable since those are stranded able and make easier to lay on the floor.
go newegg.ccom or something or even amazon
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
jmizoguchi wrote:
yes..
Thank you for your help!!
Should I set up the netgear as the access point or the dlink? Whatever seems to you to be easier.
Luminary
Makes no differenes. Based on which you think is better favor to use a router for firewall setting etc
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 11 replies
  • 6518 views
  • 0 kudos
  • 2 in conversation
Top Contributors
