× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Security key is correct but saying it isn't
Bestpretzle
internet was working fine and went to change the security encry and put the wrong security key went logged into the router got the right one put it in and it's saying "The network security key isn't correct. please try again.
Model: WGR614v7|Cable/DSL Wireless Router 54 Mbps/2.4 GHz|EOL
Message 1 of 2
Accepted Solutions
Bestpretzle
Re: Security key is correct but saying it isn't
after a hour i had regenerated the passphrase a couple times and it now works. still not 100% sure what had happened.
Message 2 of 2
All Replies
Bestpretzle
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 8296 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
