Reply
Follower
Unable to access Router login Site
I recently installed a WNR834B RangeMax Next wireless router. It is hooked to my cable modem and then directly hardwired to my pc. I use the Wireless for my laptop. I am able to surf the net on both my laptop and pc. But I am unable to access the router login page to adjust any settings. Initial setup went fine with no glitches. Also I bought the WN 511b for my laptop to get the faster speeds which this router provides. Installation for it went fine also, but it doesnt see anything over 54Mb, should it? (Thought I would at least see something over the 54Mb since its advertised for up to 270Mbps) great signal strength though. Is there a settign on the page i cant access which enables this? What should I do?
Re: Unable to access Router login Site
While I don't have this particular router the default wireless channel mode setting in my DG834PN was g & b (so also a max of 54) and required me to alter it for the faster speed.
Hi you can uprage your netgear WNR834B to the newest firmware version and get the fixes that might help you. Also try to download the latest drivers for your WN511B to achieve speed of more than 54mbps. Just make sure you set your speed to 11 b/g/n.
Virtuoso
Your first step would be to gain access to the router settings. How are you trying at the moment, are you using something like www.routerlogin.net, or typing in the IP address? Typically one of the following IP addresses will work;
http://192.168.1.1 or http://192.168.0.1
Whats going on I cant access the router login site ,it either times out ,freezes or dell intercedes with a usless alternative. All I want is access to my settings where do I go from here " a £1.50 per min phone call?"
Virtuoso
Assuming you have Internet access though the router, if you type ipconfig /all at a Command Prompt then the IP address of the gateway should be the router address. You should be able to access the login prompt by typing this into a browser, typically this will be http://192.168.1.1 or http://192.168.0.1
Novice
On some isp's you may need to use HTTP://10.0.0.1 to log on to your router. That's what I have to do at AT&T Yahoo dsl.
I am also having trouble logging ont the router I have a WNR1000 and am running windows 7. Whenever I try to access the router I get a dialogue box asking for a username and password which I enter as admin and password respectively. The dialogue box with a warning that the server is requesting that the user name and password be sent in an insecure manner. When I press ok the dialogue box is re-presented, I enter the username and password and press ok again and the same thing happens. Please tell me what I am doing wrong
Tom
Dear Tom,
I just Monday afternoon (well yesterday now) purchased two WNR1000v3 for a client.
I installed one on their very high speed SF DSL network and it is running.
I've been working on the second unit until now and I'm a bit brain dead.
We bought the Version 3 device. The Netgear support forum has different help for the other versions -- version 1 and version 2.
I suggest that you go to the Netgear home page at http://www.netgear.com/
Select Support
Find your particular version of this router
See if there is a Firmware update for your problem.
I updated the firmware on the version 3 router
from WNR1000v3-V1.0.2.18_47.0.52NA.chk
to WNR1000v3-V1.0.2.26_51.0.59NA.chk
I do not permit automatic update of firmware on my networks.
I hope I've been of help. If not, please ask again.
Luminary
detail the issues
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
I have forgotten my pass. on my router, how do i retieve it ??
Luminary
If you forgot login password to the router that not same as default
User admin
Pass password
Then you MUST hard reset
See router reset in my sig below
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 11 replies
  • 363500 views
  • 0 kudos
  • 10 in conversation
Top Contributors
