Reply
WLAN access rejected - WNDR3700v2
My wireless devices are dropping from network and then reconnecting. I have a mix of XP Laptop, XP desktop, Andriod, Blackberry, Windows 7. Signal is perfect in my house. I have WNDR3700v2, Firmware Version V1.0.0.10.
All router settings are default except, I have MAC filtering, and WPA2-PSK [AES]. Error from Log: [WLAN access rejected: incorrect security] from MAC address xx:xx:xx:xx:xx:xx, Saturday, November 05,2011 08:09:10.
Thanks
Luminary
Re: WLAN access rejected - WNDR3700v2
you need to DISABLE the mac filter first and see connection can be made.
if this the same device used to work then HARD RESET and manually configure the router and I would observer
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Discussion Stats
  • 1 reply
  • 2399 views
  • 0 kudos
  • 2 in conversation
Top Contributors
