Reply
WNDR3400 - Cannot connect to internet
My internet connection all of the sudden dropped on my WNDR3400 Wireless router. I have been using it fine for 3 months, but my connection all of the sudden droppend and I haven't been able to get it back. Here is what I have tried and verified so far:
My internet connection works fine, meaning I can connect directly to the internet from my PC to my ISP cable router.
All lights on the Netgear router seem to be indicating that everything is functioning fine, including the internet light (orange flashing). I've tried connecting through one of the ethernet ports, and the wireless signal is strong and I can connect to the router through the wireless signal.
I can log into the router and modify its settings, however the router shows that there is no internet connection when trying to run firmware updates.
To summarize:
1. I can connect to the internet
2. I can connect to the wireless - but it does not route to the internet
3. I can connect via ethernet port - does not route to the internet
I tried to reset the router multiple times, but no change. I have tried a factory reset, but it still will not connect to the internet even with all default settings.
I also have connected the cable from the internet port on the router (not the LAN port) to the ISP provided cable modem.
I'm using both Mac OSX and Windows 7, this same issue occurs on both platforms.
My ISP is Comcast, but as mentioned, I can connect to the internet directly when not using the router.
If anyone could help me to identify the problem, I would greatly appreciate it.
Luminary
Re: WNDR3400 - Cannot connect to internet
mac spoof the router using one of mac or pc's mac address and changed that under the basic setting of the netgear router
also turn off the cable modem for 30min to cycle the comcast network and try again
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Novice
Hi soyelfunk, I also have a WNDR3400 with Comcast as my ISP, and I have a suggestion. I may not be an expert like June, but that "orange flashing internet light" doesn't sound right to me. I actually had that happen once, and it turned out to be a defective Cat5 cable! No idea how a cable can suddenly go bad, but that's what happened to me and it would only cost you a few bucks to replace - better yet free if you have a spare as I did. Hope this helps, good luck!
I went for the easier route and turned off the modem for about 10 minutes. Turns out that did the job. Also, I tried the cable thing before, but it didn't work out, but a great suggestion none the less. I had an IT professor that said 80% of networking problems are in the cabling. Not sure how true that stat is, but I take it into consideration every time I troubleshoot problems.
Thanks for your help.
Answer: turn off router for 10-30 min to allow comcast to recycle
Luminary
so my suggestion just worked huh... usually on comcast or cable modem services, it needs to be OFF for good duration or will cause issues.
enjoy your new toy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Novice
Yay! Glad your problem was resolved so easily!
Is your light still orange/amber, or are they all nice and green?
I have the same problem but all my lights on my router are green. Would the waiting for 10-30 minutes work too? Thanks for your time Smiley Surprised
All my lights are green. So it is receiving internet from the modem. But it doesn't push out internet. Would the 10-30 min test work on this too?
Luminary
if you have cable modem then
1. turn off the cable modem and unplug ethernet cable
2. wait for few min (20min)
3. turn on the cable modem only and do NOT plug any ethernet cable
4. wait until all the light up on cable modem
5. ONLY after all the light is up. hook up a router behind the cable modem
6. you should able to get public IP from the ISP and it will show up in the router status when you login the router.
** remove the BATTERY from the cable modem if built-in and follow from #1~
still have issues.. do mac spoofing like it been done here by OP
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
i just got this modem and my windows vista laptop will not connect to the internet (wireless) connects to network but it says local only. . .
my desktop works (wired)
as does cell phones and tablet (wireless)
any sugestions?
thanks
Luminary
any sugestions?
thanks
WNDR3400 is not modem. It is called ROUTER.
Do not hijack the the thread which does not seems to fit the OP issues.
http://forum1.netgear.com/forumdisplay.php?f=33
REPOST above and do NOT click on any other model categories.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
^ This is what my WNDR3400 V1 did all the time after the latest firmware 1.0.050 upgrade. The no-internet issue started happening all the time, and then reboots and power cycles would only fix the problem for a short duration, then it was back to no-internet. Additionally, Netgear Genie network map showed the wrong picture for the WDNR3400 router, and it showed the Brother MFC-7360n printer as connected, but then no computer in the house could print to it unless I connected that computer to the router using an ethernet cable.
To fix, I downgraded the router to 1.0.0.34 and ran it a few days. All the problems went away. I then downloaded 1.0.0.50 firmware and installed that on the router. No problems since. Anytime I changed firmware, I downloaded the firmware to PC, hooked ethernet cable to the router, used the browser and the router's GUI to upload firmware from PC to router, as described in the user manual. I then used the reset-to-factory button on router and also did a power cycle. Then went back into the router and set everything the way I wanted it.
So far, so good. I just wanted to document my apparent solution, in case it saves somebody else time and effort. I definitely have the V1 version of the router.
Discussion Stats
  • 11 replies
  • 9915 views
  • 0 kudos
  • 6 in conversation
Top Contributors
