Reply
WNDR3400 V1 or V2
I have no idea if I have V1 or V2 and it doesn't say on my unit it does say N600 Dual Band router. How do you tell which one it is and where do I go to get the latest updates for it.
Luminary
Re: WNDR3400 V1 or V2
bottom of the router will say V2 if you have V2 otherwise you have v1
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Do you know where on the bottom it would be written? There is stuff at both ends of the bottom and in the middle. I cannot find if it would be in a string like WNDR3400 or something else. Also is there away to subscribe to this part of the forum so when you post a message I will get an email I have a new post to it? :confused:
Apprentice
Look on the box on the side it will say V2 if a V2. Also, what is the firmware version, that will tell you if you have a v1 or v2.
Luminary
Label at bottom of the router
All the product info is labeled in router itself
Like you have v1
If you had v2 it will say wndr3400 v2
ONLY v1 have nothing after wndr3400
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
I'm looking at the sides of the box and I don't see anything about V1 or V2.
Luminary
you will not find in the retail box on some model.. you have to look at actual router and see at bottom of the router .
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Ok then it is a V 1.
Thanks for the replies and clearing this up.
Luminary
Your welcome Smiley Happy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
V1 isn't upgradeable to V2 by software is it?
Apprentice
No it is not.
Luminary
No ......will not
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Okay, just thought I'd ask. Thanks for replying.
Luminary
enjoy the products Smiley Happy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 13 replies
  • 10997 views
  • 0 kudos
  • 3 in conversation
Top Contributors
