Reply
WNDR3400 can't login to access router settings
Just set up a new WNDR3400 to replace a cheap and troublesome router because I've always had trouble-free operation with Netgear stuff... and I can't login to access the router settings. Using "admin" and "password" as per the manual.
When I try, it gives me the message to check that I'm connected to the router, which I am, as I'm using it to type this message. I've tried it wireless and wired.
Any ideas?
Re: WNDR3400 can't login to access router settings
OK, in reading through the troubleshooting FAQ, it looks as though the Genie is only partially functional, and doesn't work at all on the 5G network.
However, I can't log in to www.routerlogin.net, either. Error is message is "can't find server".
Any help would be truly appreciated.
Found the problem. The router was sitting behind our BT router/modem - in other words, the CAT5 cable from the BT router was going into a network port, not into the Internet port. I can log in to the router now either through Genie or the gateway ID.
Luminary
http://www.downloads.netgear.com/files/GDC/WNDR3400V3/WNDR3400v3_Genie_IG_21Dec2012.pdf
Most all router has COLOR CODED and also has stick to tell you only to connect certain port for broadband ( basic setup)
Unless you are color blind then that would be an issues Smiley HappySmiley Happy
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Thanks for that. :confused: However, when it's connected like that, I can't access the other computers and printers on the rest of the network. So, I'm not color blind, and there was a reason for what I was doing.
Luminary
Wireless and wired device behind may not communicate if wireless isolation feature is enabled in the router GUI
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Well, I can't log back into the router control panel either after changing SSID and setting passwords. Before that, no problem, works as designed. Also, there is no field to change default login name?
Either wireless or cable, direct connection. After reset to default settings, no problem.
This seems to be a software bug in most recent firmware.
Luminary
You can NOT change default login name on all Netgear home end routers
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
WOW! So does that mean that anyone could log into my router by guessing (not much of a guess) admin / password? Which of course means they could change all my wireless settings as well?:confused:
Luminary
You can NOT change user name but you CAN change password!!
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Virtuoso
An example of why in general this doesn’t make any practical difference;
Which is harder to work out :-
User – elephant
P/W – 12345678
Or
User – admin
P/W – elephant12345678
I know of plenty of other network devices that only allow the P/W to be changed, and others that allow for multiple accounts with different user IDs, but still retain an unchangeable ‘root’ or ‘admin’ account (with changeable P/W only).
Discussion Stats
  • 10 replies
  • 16255 views
  • 0 kudos
  • 5 in conversation
Top Contributors
