Reply
Novice
WNDR3400v2 reset?
Good morning.
My internet provider is sending me a new modem to self install. (currently i am using the old modem configured with my Netgear WNDR3400v2) My question is this: Will i need to reset my router to factory defaults after i install my new modem?
Thanks and regards, dennis..Memphis, TN
Luminary
Re: WNDR3400v2 reset?
too vague since there is no broadband modem info, type of broadband and how network was setup.
in basic you should be as easy swap
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Novice
Further information for your consideration:
Current modem in use with my WNDR 3400v2 router:
Scientific Atlanta model DPX2203c (eTMA. - internet + phone) DOCSIS 2
IP/Broadband provider: Internet service level: Comcast Performance Internet. (recent speed test 23 down - 5up). Comcast installed the modem, I added the Netgear Router 3 months ago.
In reference to my initial question: Comcast is sending me a new DOCSIS 3 modem (Arris model 722G eTMA)
jmizojuchi, I took the time to provide the information you requested..... So now I would expect you to have the courtesy and respect to provide me with more than a trunkated 100 character dismissive answer.
Kind regards, Dennis, Memphis, TN
Luminary
good luck with your attitude.... I have better thing to do
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Novice
Ahhhh.. yes, the swap worked smoothly. i just configured the new modem and then plugged in the WNDR3400v2. everything worked perfectly. kind regards, dennis.
Discussion Stats
  • 4 replies
  • 2846 views
  • 0 kudos
  • 2 in conversation
Top Contributors
