Reply
Novice
WNDR3700-V3 and Wii
Wii will not connect wirelessly to WNDR3700-V3. I've tried regular wireless and guest network, with/without security, no MAC filtering. I saw a post on Nintendo that DNS might be the trouble, so I explicitly entered DNS servers, all to no avail. Wired and wireless PCs work just fine. Both Wii and N600 have latest firmware. Sounds like the same problem as taylorcs (but I don't have a Kindle to verify). Was looking forward to having DB wireless and Gigabit ethernet in a single solution, but it's looking doubtful. Any help would be appreciated.
Tutor
Re: WNDR3700-V3 and Wii
Is this on the 2.4 or 5GHz radio?
Luminary
what is the errode you get on wii?
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Novice
I have a 3700 and set up a 3300 for my parents, both are getting error code 52030 on the 2.4 GHz signal.
Novice
I just got it to work my turning off the NAT Filtering.
Tutor
Is UPnP enabled?
_____
WNDR3700v1 (v1.0.7.98NA) - Router uptime (d:h:m:s): 1155:02:31:46 - How To Check and Change Your Router's Firmware: http://forum1.netgear.com/showthread.php?t=63234
Novice
I have a wndr 3700. I am trying to wirelessly connect my wii to my router. I went through the setup on my wii and when I try to test, it just trys to connect, its been doing it now for over 20 minutes and I cant do anything to get out of that state, I hit the power button, menu, nothing works. I have to unplug the wii to break the connection, thats the only thing that works. Please help, thanks.
I had trouble getting my Wii to connect.
I changed the router's 2.4Ghz channel setting from "Auto" to an actual number, and the Wii connected right away.
I did this as well, but I choose channel 11 & it did not work, but when I tried channel 1 it worked right away.
Discussion Stats
  • 8 replies
  • 4794 views
  • 0 kudos
  • 8 in conversation
Top Contributors
