Reply
WNDR3800 Firmware
Can anyone confirm if this is right or wrong.
I've used the Advanced menu to search for a firmware update.
The search has come back saying I'm currently running v1.0.0.82 and should upgrade to v1.0.0.84 - from what I can tell it looks like its reporting the firmware for the WNDR4000 - this can't be right.
I'm using firmware v1.0.0.18 on my WNDR3800.
Is this a bug ?
Mark
Luminary
Re: WNDR3800 Firmware
manually download
http://support.netgear.com/app/products/model/a_id/18163
also report the finding with support at my.netgear.com
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Novice
Is this a bug ?
Mark
Hi,
I think you are talking about the GUI language version. The V1.0.0.84 version for GUI language is correct and it is latest version.
You can go to ADVANCED page to check the Router Information. There are two information: Firmware version and GUI Language Version. So I think your WNDR3800 have upgraded to V1.0.0.18 firmware but your GUI language is still V1.0.0.82 and there is newer version V1.0.0.84 now.
Best regards,
Jake
Discussion Stats
  • 2 replies
  • 4585 views
  • 0 kudos
  • 3 in conversation
Top Contributors
