Reply
WNDR4500 and firewall
Hi,
I have just purchased and set up my 4500 and have it all up and running.
My one problem is that when I scan my computer (wired to the 4500) on shields up, my ports are all shown as closed but visible. I find this unusual as they should really be stealthed.
I have spoken to tech support and they confirm that the firewall is enabled.
As the 4500 is not a modem, I have a firewall in my modem that if I switch on stealths everything. If this modem firewall can stealth the ports why can't the 4500? One of my buying points was the double firewall protection, am I doing something wrong?
Thanks for your anticipated replies
Luminary
Re: WNDR4500 and firewall
what is the broadband modem.....model
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Thats a good question as I am on a temporary one at the moment. I have brought a sitecom ADSL 2+ modem to use, but cant get it to work and their tech support only work Monday to Friday, so can't ask them about it until then. It only has an option for PPPOA connection where as my isp uses ETHOA.
Until Monday I am using my old Belkin modem router with wireless etc turned off and just using it as a pure modem.
Hopefully Sitecom can sort my connection problems on Monday.
Luminary
If you are using ethoa then you like need to have you ISP assist you to see if you can pass routable IP to your 4500.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Hi and thanks for your reply, unfortunately I am not sure what that means.
I have spoken to them on the phone and they have emailed me the settings for the modem once I get instructions on how to set it up for ethoa. My ISP is unbundled in the local exchange and has its own kit in there.
Luminary
You need to ask how you can make the setting correctly to work with your own router behind their provide broadband modem
Other options are you may need to use Netgear router as an access point
http://kb.netgear.com/app/answers/detail/a_id/965
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Ok, thanks, I will ask them on Monday.
Luminary
keep update your issues...
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Hi,
Thanks for all your help. I managed to get hold of a modem on its own after much searching. Its all up and running with the new WNDR4500 and the firewall is stealth, so I am happy Smiley Happy
Luminary
Sounds great! Enjoy!!
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 9 replies
  • 5660 views
  • 0 kudos
  • 2 in conversation
Top Contributors
