Reply
Tutor
WNR2000v3 and Dish network 922 connection
Hello!
I am attempting to connect my Dish network 922 to my router. The device shows DHCP is ok, but internet and server connections fail. The device shows an IP address. My router shows the device on the genie. I have contacted my ISP (Verizon) and Dish network techs, who both say my router is not allowing the device to connect. I am not a tech genius, but can get my way through. Any advice would be GREATLY appreciated.
I should also note that I have a TV, DVD, phone and Windows 7 computer that connect with no problems.
Tutor
Re: WNR2000v3 and Dish network 922 connection
Hello? Is anybody out there?
Luminary
put google DNS on Dish network's network settings.
Is there any error code on dish unit?
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Tutor
I set my DNS address to google's IPv4 & IPv6 address. Tried to connect and it did the same thing: DHCP = ok, internet and server connections = fail.
When I had set the DNS address and did the command prompt check (per google's instruct) I got many strings of "request timed out". I did not receive any error codes.
Luminary
you put this on DISH device correct?
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Tutor
I cannot get to settings on the dish receiver. It auto acquires.
Luminary
Also seem maybe common issues with 922 to have an issues
http://www.dbstalk.com/showthread.php?t=181980
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Tutor
Thanks! I will try posting there.
Luminary
I wasn't really point you to different forum and leave here but the point was that I don't think issues with router manufacture.
I would call Dish support about this
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Tutor
Oh I have, several times. They read off their standard checks:
Plug into the wall
Connect directly to router
Reboot receiver
Reboot router
I've done it all....they eventually say it's my ISP or router. When the only client that will not connect to my router is the receiver, then I would say it's the receiver.
Oh and BTW, this is my second receiver, just in case it was a defective first receiver. Same problem......
Luminary
Maybe try different model if you can not change any networking setting on dish
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Tutor
I tried connecting directly into my modem to the receiver and got the same results. I think it is Dish.
Luminary
I think so too!
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 12 replies
  • 5543 views
  • 1 kudo
  • 2 in conversation
Top Contributors
