Reply
WNR2000v3 router keeps on dropping connection? please help anyone who has fixed this
My internet dropped two times as I typed and I have tried everything to fix this. My router connected to my modem (brand : zoom). I have tried lowering the MTU size to 1492 and I have tried multiple channels, I've also downgraded my router to version 1.1.1.58. My Ipod touch , Dell laptop and Playstation 3 are all connected to my router but I dont understand that it worked perfectly fine one day and over night itt started droping periodically over 5 minutes. Please help anyone i'm getting desperate??? :mad::confused:
Luminary
Re: WNR2000v3 router keeps on dropping connection? please help anyone who has fixed t
Hard reset the router first and observe the issues
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Did that and it still drops Smiley Sad
Did that and still dropping Smiley Sad
Luminary
change channel for wireless
1,6,11 if you choice to use
http://www.metageek.net/products/inssider/
use the tool to understand the surround wireless broadcasting including yours
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
i've tried all those channels and it still drops Smiley Sad
Luminary
you may have bad internal wireless and/or power supply which are causing the issues
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
What do you mean by "power supply"?
Luminary
power supply is black piece that applies to router ....
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Ok heres my router log from the past couple minutes. Can you make anything out of this? The nat_del and etc stuff appears to happen around the time my connection drops?
[UPnP set event: del_nat_rule] from source 192.168.1.3 Monday, May 28,2012 11:58:07
[DHCP IP: 192.168.1.4] to MAC address 24:b6:fd:27:52:71, Monday, May 28,2012 11:58:06
[UPnP set event: add_nat_rule] from source 192.168.1.3 Monday, May 28,2012 11:57:57
[UPnP set event: del_nat_rule] from source 192.168.1.4 Monday, May 28,2012 11:57:53
[DHCP IP: 192.168.1.3] to MAC address 64:27:37:68:a5:23,
Luminary
Upnp log...
try disable uPNP in the router settings
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
jmizoguchi wrote:
Upnp log...
ok but what does the log mean and whats it trying to do?
jmizoguchi wrote:
Upnp log...
& my connection dropped again......:mad::confused:
jmizoguchi wrote:
Upnp log...
another log with "DHCP IP"???
[DHCP IP: 192.168.1.3] to MAC address 64:27:37:68:a5:23, Monday, May 28,2012 12:15:01
[DHCP IP: 192.168.1.2] to MAC address 28:0d:fc:46:f8:18, Monday, May 28,2012 12:14:24
[DHCP IP: 192.168.1.3] to MAC address 64:27:37:68:a5:23, Monday, May 28,2012 12:11:13
[DHCP IP: 192.168.1.2] to MAC address 28:0d:fc:46:f8:18, Monday, May 28,2012 12:06:50
Luminary
http://en.wikipedia.org/wiki/Upnp
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
another drop off?
Luminary
this is DHCP release to it's mac address
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
then that must be whats causing the internet drops since they are happening at the exact same time? how do I stop this?
Luminary
assign static IP on device side and see how it behaves
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
sorry but how do you assign a static ip??
Luminary
ch?client=safari&rls=en&q=how+do+you+assign+a+static+ip&ie=UTF-8&oe=UTF-8
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Luminary
http://www.google.com/search?client=safari&rls=en&q=how+do+you+assign+a+static+ip&ie=UTF-8&oe=UTF-8
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Initiate
Do you mind actually posting something that is useful and helpful to those of us with this annoying dropping of connection?
I already have a static IP and I'm not dropping UNpP because I have sharing of network printers.
Also, the whole reason I switched from Linksys to Netgear in the first place was because the router kept shutting down my connection.
It is annoying that nothing changes on the router and all the sudden the connection is dropped and the wireless network cannot be found. I would not have this silly WRN2000 router if my wireless G router of 6 years had not died for no apparent reason.
Again, please post something useful instead of annoying and patronizing google searches. We come to these forums for useful information because as the previous poster says, the calls to technology were unsuccessful.
All of you tech guys treat us like idiots and expect us to continue buying your products, but I tell you one thing, if a simple problem like this cannot be figured out I will take this back to the store and get a competitor product. Thanks very much.
There is no reason my router should drop or stop my wireless connection EVER, unless I shut off the router, disconnect the internet or armageddon hits. PERIOD.
OH and I have windows 7 and a stellar cable modem connection. My G router NEVER dropped the wireless. I have had this N router a few days and it drops it several times a day. VERY ANNOYING.
Thanks in advance for you help with this matter.
Luminary
Good luck and enjoy your day
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
rtv Aspirant
it's all you ever get from this "jmizoguchi" guy...i've been on this site several times looking for help on this or that and this time i'm here because i have the same issue..dropping off every minute and reconnecting for 30 sec then dropping..over and over. as soon as i saw it was "jmizoguchi" reesponding i knew i'd not any help here.
Discussion Stats
  • 29 replies
  • 20384 views
  • 1 kudo
  • 8 in conversation
Top Contributors
