Reply
Follower
What is NETGEAR Genie?
Prodigy
Re: What is NETGEAR Genie?
Click the link - the page tells you what Netgear Genie is and even has a YouTube video explaining it.
What I'd like to know is what routers does it support.
Give a man a fish, feed him for a day
Teach a man to fish, feed him for life.
Luminary
genie is software that will allow easier access to the basic information about the router and also if you need to change you can login into the router GUI as well. when using genie access the router GUI via wireless while using genie will not work because new firmware has updated to block access to router GUI from wireless.
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
YeZ NETGEAR Expert
NETGEAR Expert
NETGEAR Genie (http://www.netgear.com/genie) is a dashboard allowing you to easily manage your home network, name a few things Genie does:
1. Allow you to manage router settings like wireless settings, guest acces, Traffic metering, ReadySHARE
2. Allow you to activate and manage parental controls
3. A network map allows you to see visually what devices are connected to your network
4. It will constantly monitor your Internet connectivity, if the computer disconnects from the Internet, Genie will be able to help you to auto fix the issue, it can fix most common wireless related issues for example.
5. You can use Genie to connect to any wireless network, and can check wireless interference in your neighborhood.
BTW, a correction to one of the comments in this topic, router firmware does allow a client to access its GUI from both wireless and wired connection, there is no new firmware to restrict only wired connection. The only recommendation NETGEAR has is to not update the router firmware through wireless connection.
Luminary
4300v2 does... limited from wireless for router gui using genie or by standard IP Smiley Happy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Apprentice
GENIE desn't identify all of my devices in the network map. 3700 V1 4.98
4xR6300 AC1750 V1 - V1.0.2.78_1.0.58 whole house router+wireless. 51 devices connected.
1xWNDR3700 N600 V2 - V1.0.1.14 provides internet to my first floor and back yard
2xWNDR3400 N600 V1 - V1.0.0.50_20.0.59 running faithfully in a crowded apt building
2xWNDR3300 N600 V1 - V1.0.45 over 2 years since reboot
3xWRT54G/GS - DD-WRT what can you say about the legendary WRT54
DIR-615 vC1 3.13NA - great little router
DIR-655 vA3 1.37NA - RETIRED never worked right with OOMA
EDIMAX EW-7416APn v2 1.13
all NETGEARS are factory recertified except 1xWNDR3400
HOW TO: My router firmware upgrade instructions:
http://forum1.netgear.com/showpost.php?p=425691&postcount=4
HOW TO: Reinstall the firmware on a router without the setup CD recovery tool
http://kb.netgear.com/app/answers/detail/a_id/19841/~/reinstall-the-firmware-on-a-router-without-the-setup-cd-recovery-tool
HOW TO: Extend AP on separate LAN
http://forum1.netgear.com/showpost.php?p=479421&postcount=5
HOW TO: Extend AP on the same LAN
http://forum1.netgear.com/showpost.php?p=481991&postcount=2
You can click on the icon on the network map, click on modify and change it to a different icon identifying it as a camera, gaming console etc...
You are correct, Genie does not recognize all devices. It is being enhanced.
Meanwhile, Please do use the following workaround.
Thanks
Som
Apprentice
updating f/w to 1.0.7.98 solved the problem
:confused:
I just purchased a new Netgear N600, and I have had so many problems, you just can't believe. It's so bad that I can't even log into Netgear genie. Been totally screwed by IYOGI who totally hosed my system, that I am fed up with them. I have no good words for Netgear either, because they sell a product, and pawn it off to a bunch of foreigners who want to always charge you to fix their mistakes. Really, totally FED UP.
Tutor
From my perspective, I wouldn't bother with the Netgear Genie and would log directly into the router. I see no practical use for the Netgear Genie other than to unnecessarily eat resources. Good luck with your issue.
_____
WNDR3700v1 (v1.0.7.98NA) - Router uptime (d:h:m:s): 1155:02:31:46 - How To Check and Change Your Router's Firmware: http://forum1.netgear.com/showthread.php?t=63234
Discussion Stats
  • 9 replies
  • 15674 views
  • 0 kudos
  • 8 in conversation
Top Contributors
