Reply
Novice
Who is on my router.
Is there any way to find all the wireless devices connected to my router?
Luminary
Re: Who is on my router.
if you are well encrypted and uses WPA2 and you should not worried.
look under attach devices and/or google also angry IP scanner and see if you more devices then you own
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Apprentice
Well yeah. Access the router's admin pages and simply click on 'attached devices'.
Novice
Maintenance, Attached Devices
My list shows the named PCs as clients, but the other devices are listed as . I assume they are my wife's and my cell phones and my printer, but it would be good to confirm this. I know I can match up MAC addresses, but is there any way to have attached devices that are not PCs show up with a name?
Luminary
some it does to get correct ARP request.
BEST is inventory all the mac address and have on hand. if you have WPA2 encryption you should not worried about in the first place
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Match the MAC adddresses.
My "unknowns" have all been my iPads or iPhones that were sleeping and not fully connected, but the router knows they're there.
-- Chuck
Novice
Did anyone ever solve the "No Attached Devices Showing" issue? - I've looked but can't find an answer - I show no devices either wired or wireless. BTW - WPA2 is cracked as easily as WEP was so that is a false sense of security. Best solution is to log the macs as suggested....
Novice
I have to reboot my router to get attached devices to show. That lasts for a while, but then have to reboot again. PITA.
Luminary
WEP and WPA-TKIP are most hackable
WPA2-AES should be most safest. It takes longer duration to crack algorithm which most road warrior want deal with but anything is hackable unless you use WPA2/WPA enterprise
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Novice
I have to reboot router whenever I want to see attached devices. Major PITA.
Discussion Stats
  • 10 replies
  • 9912 views
  • 0 kudos
  • 8 in conversation
Top Contributors
