Reply
WiFi keeps disconnecting? Help!
I have a NETGEAR DG834GT Super wireless adsl modem router. It has been working fine since we bought it in 2007, we turn it off every night, and on every morning, and all of a sudden the wifi stops working. I have tried restarting it by turning it off, waiting 45 seconds, and turning it on again, but I still get the problem. I have tried all wireless channels (1 to 13), modes (g, b and auto 108mbps), I have upgraded to the latest firmware, Restored factory default settings, and re-entered ettings manually, changing and removing password of wifi access point, but it still keeps disconnecting the wifi after 30 seconds or so after power-on. I also have tried turning off all connected devices one by one, to no avail. The 2 computers connected directly via ethernet ports work fine!
Could someone please help, I desperately need this working again!! Thanks.
Retired_Member
Re: WiFi keeps disconnecting? Help!
Load INSSIDER it's a visual tool, load on laptop, turn on wireless router see if ssid disapears after 30 seconds. If it does your router is bad and turning on and off everynight is not a good idea most devices fail on turn as do most lightbulbs.
Apprentice
WendyOR wrote:
...bought it in 2007...
searay's suggestion to use inSSIDer is a good 'un.
I'd say though, it sounds like your router's wifi's conked out.
According to jmizoguchi on another thread, you could still keep it to use as a switch. Smiley Wink
Luminary
behavior probably is bad wifi unit.
I would check make sure that power supply has proper voltage as well. this will cause the wifi card not to turn up or acts up.
I say replace the power supply and if continue to have an issue, new router could be your horizon
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Using inSSIDer I found that my network stays active for 2 minutes and 40 seconds, and then the SSID dissapears. Here is a picture of my graph: (my network is alled 'Wendy')
You can also see in the graph tha my network is -70dB, all the others are around -80dB?? Can someone tell me if I can save my router? Smiley Sad
Luminary
Too many of channel 6
Use channel 11
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Tried channel 11, this time it stayed on for 3 minutes 14 seconds, then stopped again. I have noticed that the graph shows my network's amplitude (dB) is very jagged, whilst all other networks in range have smooth lines. :confused:
So does everyone here think my router is conked out, and I'll have to buy a new one? Smiley Sad
Apprentice
As said before, you need a new router.
Luminary
Suggestion is test out different location before any
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 10 replies
  • 18239 views
  • 0 kudos
  • 4 in conversation
Top Contributors
