Reply
Wireless-G Router WGR614v9 - password
Hello
I do not know the user name or password for my router and wonder how I may go about resetting it.
Thanks for any advice.
High1
Guide
Re: Wireless-G Router WGR614v9 - password
Hard reset the router and reconfigure it.
By default: admin password To reset, there is a little hole right near the antenna in the back, stick a pen and wait until the V in the front starts flashing orange.
Hello sabretooth
Many thanks for your reply.
I have done that: resetting the router for 20 secs, then turning it off at the mains foa short while, and resetting the router again before leaving it to settle down. The four lights at the front of the router that should be on are on.
I then go to the address bar at type in either http://www.routerlogin.net/ or the IP address which I get through the cmd prompt. I get a dialogue box asking me for a user name and password (I put in the default ones) and after trying it a couple of times I get another Web page that says: 'System Authentication Failed. Please contact your system administrator for the correct information'.
Would I need to contact my ISP about this?
Thanks
Luminary
if this router was supplied by the ISP then you may have branded firmware which are NOT same as netgear default user/pass
If this is the case contact ISP support
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Hello jmizoguchi
Oh, right. Thanks for explaining the difference.
I will contact the ISP.
Cheers
High1
Luminary
Good luck and post your finding
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Guide
Look all over the router as ISPs usually put the login and password on the label of the router.
Luminary
not all does
comcast don't think does. comcast uses cusadmin as username on some unit
sky also are common.. username on sky is sky
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Hello jmizoguchi
I managed to log-in with sky as the password, thanks.
I have changed the channel to 1 and the connection seems a lot more reliable.
I am getting the following results in Xirrus:
Speed:
Ping: 35ms
Download speed: 2.96Mbps
Upload speed: 0.69Mbps
Quality test:
Packet loss 0%
Ping 32ms
Jitter 4ms
Connection test:
Test Address Summary Result
DNS Reachable 192.168.0.1 Ping: 5 of 5, 3 msec latency - Pass
Gateway Reachable 192.168.0.1 Ping: 5 of 5, 6 msec latency - Pass
DNS Lookup www.google.com IP address: 173.194.66.105 - Pass
Internet Reachable 173.194.66.105 Ping: 5 of 5, 37 msec latency - Pass
It all seems OK at the moment.
Thanks for your help.
Luminary
Your welcome!!!
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 10 replies
  • 20907 views
  • 0 kudos
  • 4 in conversation
Top Contributors
