Reply
Wireless connected but no Internet access
Hi all
Route name"netgear n300 ADSL/2.Telkom network
Wireless connected,lED glowing as green.but unable to access any web pages.
Wt is probable causes for not access web.i disabled all firewall.its not working for all of my friends systems for last one week.suddenly it was happened.i tired of calling those Telkom guys.please any one help to resolve this issue
Re: Wireless connected but no Internet access
Hello,any one in this world to help me to resolve this headache problem,
Virtuoso
Please provide more detailed information such as;
• Router model – e.g. DGND3700, ‘Netgear N300’ is a generic name and does not identify the specific model.
• Router wireless encryption setting (e.g. WPA2)
• Is the router SSID (wireless name) visible at the computers in a scan?
• Router wireless rate(s) e.g. up to 300 Mbps (2.4GHz)
• Are the computers indicating that they are connected to the router wireless at all?
• Do you have the router Wireless Access List enabled?
• What firewalls did you disable?
And any other information you can think of that might help.
Without this kind of detailed information no-one is likely to be able to help.
Hi mars,
Please see below details.
• Router model – N300 DGN2200Mv2
• Router wireless encryption setting (e.g. WPA2)-WPA2-PSK AES
• Is the router SSID (wireless name) visible at the computers in a scan?its visible & connected to all laps,but no internet
• Router wireless rate(s) e.g. up to 300 Mbps (2.4GHz)-2.4GHZ-300mbps
• Are the computers indicating that they are connected to the router wireless at all?ALL COMPUTERS CONNECTED,SSID VISIBLE,BUT NO ACCES s FOR LAST 15 DAYS.
• Do you have the router Wireless Access List enabled?HOW TO CHECK
• What firewalls did you disable?WINDOWS FIREWALL-OFF
Firmware Version -V1.0.0.27_1.0.27
MAC Address 20:4E:7F:BB:A9Smiley Very HappyD
IP Address 10.0.0.2
Network Type DHCP
IP Subnet Mask 255.255.255.0
MAC Address 20:4E:7F:BB:A9Smiley Very HappyE
IP Address 41.243.48.27
Network Type PPPoE
IP Subnet Mask 255.255.255.255
Gateway IP Address 41.243.44.1
Domain Name Server 196.43.42.190
196.43.46.190
Virtuoso
IP Address 10.0.0.2
Network Type DHCP
Network Type PPPoE
196.43.46.190
Did you get that from the router, was it the Router Status page?
If your computers run a Microsoft OS, could you get a post an ‘ipconfig’ listing please by going to a Command Prompt (Start, All Programs, Accessories) and type ipconfig /all (you can copy/paste from a Command Prompt).
Hi mars,
Those details i sent i taken from Router status page,see below my PC
config details,
Windows IP Configuration
Host Name . . . . . . . . . . . . : HUAWEISS
Primary Dns Suffix . . . . . . . : vodacom.corp
Node Type . . . . . . . . . . . . : Mixed
IP Routing Enabled. . . . . . . . : Yes
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : vodacom.corp
vodacom.corp
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Broadcom NetXtreme 57xx Gigabit Cont
roller
Physical Address. . . . . . . . . : 00-1C-23-0B-7D-B0
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . : vodacom.corp
Description . . . . . . . . . . . : Intel(R) PRO/Wireless 3945ABG Networ
k Connection
Physical Address. . . . . . . . . : 00-1B-77-A9-8C-E0
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 10.112.73.87
Subnet Mask . . . . . . . . . . . : 255.255.255.192
Default Gateway . . . . . . . . . : 10.112.73.65
DHCP Server . . . . . . . . . . . : 1.1.1.1
DNS Servers . . . . . . . . . . . : 10.112.77.51
10.102.208.51
Lease Obtained. . . . . . . . . . : Wednesday, July 18, 2012 9:11:41 AM
Lease Expires . . . . . . . . . . : Wednesday, July 18, 2012 10:11:41 AM
Luminary
MAC Address 20:4E:7F:BB:A9E
Network Type PPPoE
196.43.46.190
k Connection
10.102.208.51
Seems there is some IP subnet totally different
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
sorry guys,that was taken while internet connected to OFficial LAN connection,
see below correct details of N300 router Ip config
vodacom.corp
k Connection
IP Address. . . . . . . . . . . . : 10.0.0.3
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 10.0.0.2
DHCP Server . . . . . . . . . . . : 10.0.0.2
DNS Servers . . . . . . . . . . . : 10.0.0.2
Lease Obtained. . . . . . . . . . : Wednesday, July 18, 2012 9:48:05 PM
Lease Expires . . . . . . . . . . : Thursday, July 19, 2012 9:48:05 PM
roller
Virtuoso
That listing looks correct, as it should be.
It is possible that the router isn’t properly handling the DNS IP from the ISP.
If that is the case then you should find that pinging an Internet based IP address will still work, since this does not need DNS e.g. ping 4.2.2.1
If pinging works then go to the TCP/IP properties for your network adaptor on the PC and try a manual setting for the DNS servers (you could set the DNS addresses to 4.2.2.1 / 4.2.2.2 as a test).
Hi andy,
Please see below ping test results
Pinging 4.2.2.1 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 4.2.2.1:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Kindly be advised.
Hello guys,
Any other suggestions to solve this issues.it has been experienced for last 15 days.kindly give urs valuable advices
Luminary
did you test with wired the router instead of wireless?
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
yes i checked with ethernet cable also ,its also connected,but unable to access internet.
Kindly be advised
Virtuoso
It seems that the problem is between the router and the ISP connection; can you contact the ISP to ask if they can detect your router from their end?
Hi Andy,
That is the Big problem with Telkom network.i made complaint long time before ,but they are not responding.Also i missed out telkom line number,in customer care they are asking telkom line number?Is there any other way to solve this issue ?or any way to find telkom line number?
Discussion Stats
  • 14 replies
  • 22856 views
  • 0 kudos
  • 3 in conversation
Top Contributors
