Reply
Wireless light refuses to turn on
Once again, my WGR614v7 refuses to broadcast a wireless signal. The power, Internet, and LAN1 light come in green perfectly, but the wireless light won't turn on. Sorry, I'm a really big noob at this. Can someone help? ]:
Guide
Re: Wireless light refuses to turn on
If the wireless light is off, its either the wireless radio on the router is disabled, or there is a problem on the router itself.
1. Access the router setup page. Click on Wireless Settings under "Advanced" category. Make sure Enable Wireless Router Radio and Enable SSID Broadcast are both checked. Click Apply.
2. If you found out that they were already checked, try to see if you have already using the latest firmware. You may also try to do a factory reset and reconfigure the router and see if it will fix that.
Um... how do you access the router setup page? LOL -__-;
Luminary
see router setup on my sig below. you find how to access the router
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
YOU are the "MAN"!! I spent 3 hours going over and over the instructions online and in the setup manual and no where could I find an answer to why I had no internet light. I tried the netgear forum and there you were. I enabled the router radio and the router lit up!!!!!!!!!! Houston we have liftoff!!
Why the HEII doesn't the setup wizard turn that switch on???? Netgear?
Luminary
wireless is always on but you would not able to use wireless on initial setup is normal but if you have running and stop working someone could have changed or some other glitches that my disabled.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
im sorry i was not able to follow correctly.how do i go to router set up page? how do i enable the router? im having difficulty with my netgear router supposedly the lights would turn on including the wireless light..
also when i attach the ethernet cable on the router my internet connection disconnects and this messgae appears network cable i unplugged. should there be problem with the router itself,is it defective already?
Apprentice
riaelemos wrote:
im sorry i was not able to follow correctly...
I am having difficulty understanding exactly what your problem is. This is one of the difficulties caused by "hijacking" a thread (contrary to the forum rules). You should only do this if your problem is exactly the same as described by the original poster. Should I assume that this is so?
You also need to describe the problem you are experiencing more clearly. viz. Are you setting up the router for the first time? OR, was it working well before but you started experiencing problems? What are the symptoms? What's the router model number? What other details can you provide that you think may be pertinent?
Luminary
It is possible to hav bad cable, bad LAN ports on router and/or bad network card
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
How do you access the router setup page?
NETGEAR Moderator
@DrinkingSoda See the link below on how to access the router setup page.
How do I log in to my NETGEAR home router?
ElaineM
Community Team
Discussion Stats
  • 11 replies
  • 35667 views
  • 5 kudos
  • 8 in conversation
Top Contributors
