Reply
brother wireless printer not connecting
everything was connected and running great until I updated my router firmware to the latest one...
my brother printer mfc-490cw is connecting to the router... but when i check the router console...its not there
my laptop is connected to thru wireless and my laptop is not able to detect the printer anymore
hard reset didnt do the trick.... hardcoded ipadd didnt do the trick
firewall = OFF
is there a way to downgrade the router firmware?
Luminary
Re: brother wireless printer not connecting
hard reset the router after flashing the firmware
see router reset on my sig below
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
as i said on my orig post..
Luminary
revert the firmware and test
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
After I updated to .34 firmware, I lost my brother printer as well. In order for me to connect again, I had to power off the Netgear router that last for about 1 day until it loses connection again.
Netgear support was not able to find the root cause so they told me to revert back to the previous version that was working before .24.
To revert back, just load the .24 firmware and then do a reset (on the bottom of the router with a pin) for 30 seconds.
After I reverted back to .24, my wireless connection to the printer has been running for 1 month now.
The newer firmware broke all my wireless connection, not just the printer.
firewall = OFF
Discussion Stats
  • 4 replies
  • 4736 views
  • 0 kudos
  • 3 in conversation
Top Contributors
