Reply
can't access to 192.168.0.1
hello
i try to setup dg834g v3 via 192.168.0.1 but browser give "problem loading page". no any dialog for username and password. lan and power cable is pluged correctly.
i try to hard reset with step 1-3 that jmizoguchi give in his signature but it seem nothing change. i still can't access to 192.168.0.1.
please someone help me. thank in advance.
Virtuoso
Re: can't access to 192.168.0.1
Go to a Command Prompt (Start, All Programs, Accessories) and type ipconfig /all. Look at the IP address of the Gateway, it should be a Private IP address e.g. 192.168.1.1 or 192.168.0.1 for your model router. It should not be a Public IP address or an APIPA address (169.254.x.y). If you see no mention of the Gateway then the PC IP address may be an APIPA address. The Private IP address that you see should be the one you use in the browser.
http://en.wikipedia.org/wiki/Private_network
thank you for reply.
ipconfig /all show me this
IP Address ..... 192.168.0.1
Subnet Mask ... 255.255.255.0
Defualt Gateway ... (it show nothing)
nothing look like IP address information more.
sorry, i'm not advance user. i don't know how to solve it.
another suggestion?
Virtuoso
Can you provide more of the data, in particular the DHCP stuff?
You can copy / paste from the Command Prompt window;
http://www.tech-recipes.com/rx/249/cmd-copypaste-between-window-and-command-consoledos-program/
You could also double check this;
http://documentation.netgear.com/reference/enu/wsdhcp/PreparingYourNetwork-3-12.html
many thank Mars Mug.
follow your instructions make me guess to obtain IP automatically.
now, i can access to 192.168.0.1 and done setup.
thank again Smiley HappySmiley Happy
Novice
i cna't access mine neither and heres what i get
Apprentice
So... what modem is connected to the router? Connect just the router and PC via LAN cable and nothing else. Now try the ipconfig. What is the default gateway?
Luminary
you got wrong setup ....
see router setup on my sig below.
10.0.0.1 will the IP to access the router but BASIC setup is wrong so fix that first
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Hello, When I type ipconfig /all. in my command prompt, it shows, that IP address of the Gateway, isn't 192.168.0.1 for my model router, but it should be.. how can I change it in my computer? I want to remind that I cannot access 192.168.0.1 Smiley Sad((( please help, thanks
Virtuoso
Can you post the first two numbers of the IP address please, this might help to diagnose what the problem is.
Luminary
Shota1991 wrote:
Hello,
please help,
thanks
Because you likely to have double NAT ,
See router setup on my sig below and it explains it
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
When I type ipconfig /all I get the following. It was working last time I tried to get there.
C:\Users\Claude>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : ONE01
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection* 13:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Anchorfree HSS VPN Adapter
Physical Address. . . . . . . . . : 00-FF-40-B1-C8-F7
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Local Area Connection 2:
Description . . . . . . . . . . . : Bluetooth Personal Area Network
Physical Address. . . . . . . . . : 08-ED-B9-EB-6F-52
Wireless LAN adapter Wireless Network Connection:
Description . . . . . . . . . . . : Broadcom 4313GN 802.11b/g/n 1x1 Wi-Fi Ada
pter
Physical Address. . . . . . . . . : 84-4B-F5-3A-94-B8
IPv4 Address. . . . . . . . . . . : 192.168.0.10(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Saturday, 28 September 2013 8:06:15 AM
Lease Expires . . . . . . . . . . : Saturday, 28 September 2013 5:06:31 PM
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DNS Servers . . . . . . . . . . . : 61.9.195.193
61.9.194.49
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : A0-B3-CC-44-B4-CA
IPv4 Address. . . . . . . . . . . : 192.168.0.2(Preferred)
Lease Obtained. . . . . . . . . . : Saturday, 28 September 2013 8:01:44 AM
Lease Expires . . . . . . . . . . : Saturday, 28 September 2013 5:02:00 PM
61.9.194.49
C:\Users\Claude>
Luminary
192.168.0.1 is your router ip
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 12 replies
  • 52967 views
  • 0 kudos
  • 7 in conversation
Top Contributors
