Reply
Follower
dns problems cant connect!!!
router=wnr2200
connected successfully so changed my ssid and password for added security.
tried to change router from dchp to static and using;
primary ip 192.168.1.1
default gateway 192.168.1.1
subnet mask 255.255.252.0
dns1 10.33.20.12
dns2 10.33.22.12 and it crashed.
now i cant connect to the router or the internet via the router.
i had to resort to a direct cable to post this.
my first thought is that i should have a different primary ip???
Luminary
Re: dns problems cant connect!!!
dns1 10.33.20.12
GATEWAY and Primary (PC IP) can NOT be the same
primary ip 192.168.1.10
dns1 10.33.20.12
This will work and able to access the router GUI
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Discussion Stats
  • 1 reply
  • 2619 views
  • 0 kudos
  • 2 in conversation
Top Contributors
