Reply
firmware issues 7550
i have a netgear 7550 b90-755044-15 provided to me by my isp(frontier). the problems i am haveing is sometimes it will kick off wireless devices. my cell phone will say it is connected wifi with great signal but have no internet access. if i turn the wifi on my phone off then back on i works fine for a while then does it again. my printer is also connected wifi and when that loses connection i have to power it down and turn it back on again to get connection. also, sometimes i get a poor conection so i power down my modem to reboot and get a new connection to my isp it sometimes has issues rebooting properly. what i mean by that is the modem will power up the dsl light will be green the internet light goes red and when i try to go into the modem from my wired computer i get no internet message. also on my computer it shows me connected to an unidentified network. usually this modem is connection 5. in order to get the modem to work corectly again i must press in the reset button and then go back through the initial setup. is this the crappy frontier firmware and if so does netgear have the original firmware for this modem. i cannot find it on this site in fact i dont even see my model number anywhere on there site.
Luminary
Re: firmware issues 7550
I'm certain that this is ISP branded firmware units. Very unlikely you will find same thread to your model at this moment. ISP provided unit with ISP branded firmware is commonly supported by the ISP support.
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Tutor
This isnt a "generic" part of the 3700, not sure what item rebrand it is but it's not the 3700.
As said tho, If it's a firmware issue then no users on the NG site will be able to help since it will be a ISP Specific firmware.
My ISP uses a NetGear Cable modem, and the spec on it is unlike anything on NG's site ;(.
thank you both. yes this was netgears remake of the westell 7500. the isp cannot help me all they want to do is send me a new modem this is the second one with the same problem. i think my only other option at this point is to go out and buy a new modem that doesnt have any isp firmware. i was just hopeing maybe someone knew if netgear had their own firmware for this device but it looks like they dont even want to bother with it.
You're not alone--Frontier provided me with the same unit and it does the same thing. Oh well; at least it does a good-enough as a DSL modem.
Frontier released a firmware upgrade for the 7550 (Model Name: B90-755044-15) on 28-Oct-2013. It is version VER: 06.05.02. To download and install it, do the following:
1) Connect your computer directly to the modem (not wireless)
2) Open a browser window and navigate to http://7550.us
3) Click on the file to download (B90-755044App=sw2.BBA.58.17.rel.upg)
4) Open a browser window and navigate to http://192.168.254.254 (the modem's IP address)
5) Login as administrator (username/password is admin/admin by default)
6) Click on Advanced
7) Click Yes at the warning screen
8) Click Firmware Upgrade
9) Click Upgrade Now
10) Click Browse
11) Locate the downloaded Upgrade file and click open
12) The upgrade will start. Once it is completed, the modem will reboot.
13) Once the modem has rebooted, click System Monitoring
14) Confirm the software version is VER :06.05.02
HTH
I neglected to mention in my previous post that the firmware update to VER 06.05.02 FIXED the problem of the 7550 modem/router dropping the wireless connection. I've been running it for a few days now and it no longer drops (it was dropping regularly before the update).
HTH
I have a Westell 7550 ADSL2+ Router (now owned by NetGear) and the model number is B90-755025-15 and the current version of the firmware is 06.04.20. Is the firmware you reference above (B90-755044App=sw2.BBA.58.17.rel.upg) the correct version for my model number as well? I have the device set to auto update but not sure if that is working. Thank you in advance.
I have a Westell 7550 model number B90-755025-15 with firmware version 06.04.20
Is the firmware update mentioned in this thread compatible with my model number as well? (B90-755044App=sw2.BBA.58.17.rel.upg)
Luminary
You need to contact ISP
I know ATT has firmware page as I have wormed before
Netgear will not have firmware but ISP
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
dzy Aspirant
Hello,
I know this is an oldish thread but I just applied update in the link provided and it appears to have done something to the modem part of my gateway. Everything else works fine but I now have a message:
Modem Status
Pending! Your Modem is
not Ready for Internet
Access
and it will not connect no matter what I do. Has anyone else has this type of problem after applying this firmware update? The firmware version does show as the correct one, and as I said everything else appears to be fine. Is there maybe a setting I need to change?
TIA
D
I had similar issues with drops then found out its being caused by the mircrowave since they microwave and wireless are in the same frequency range.
EDC3. Thx for the firmware instructions. I've had same problem and upgraded to V 6.05.12.
I searched for "b90-755044-15 firmware" on Google and found latest firmware upgrade on Frontier site. Kinda hidden under http://myplace.frontier.com/~firmware/
[   ]B90-755044App-VER_06.05.12.rel.upg06-May-2015 13:507.5M
Frontier had me do the modem pwr down exercise which got me no where. I'm hoping latest upgrade fixes my disconnect problem.
Know any one knows how to fix firmware on iOS and able to just hit the rep reset bottom , then configure from iOS ?!!
Does any one know who to ? My mother board just got fried , and need to fix wifi drop issue quick
NETGEAR Moderator
Hi @SmartHomePro
Welcome to the community!
Kindly provide more information on what you're trying to accomplish.
In this way, we will be able to guide you better.
  • NETGEAR model number and version
  • Brand of the modem
  • ISP
  • Network Setup
  • Number of computers/devices and its OS
ElaineM
Community Team
iSP= Frontier
Static IP
Zero computers / iOS 9.3.1
Netgear model B-90-755044-15
Rev:5
ADSL2+MODEM ROUTER
What's happening is that my devices are being dropped by the Wifi single of my Modem
NETGEAR Moderator
The model number can be verified here.
ElaineM
Community Team
Discussion Stats
  • 18 replies
  • 98820 views
  • 0 kudos
  • 11 in conversation
Top Contributors
