Reply
how can I reset my netgear password
I forgot my netgear password. Although my laptop connects with the Netgear DGND3300, my iphone can't log in to this wi-fi at all.
The password in my laptop doesn't show character.
My laptop has vista. How can I reset the password from my laptop?
Luminary
Re: how can I reset my netgear password
if you are referring to router interface to the router then you MUST hard reset the router in order to gain access. if you are referring to wireless encryption that you lost then you need to access the router interface
user admin
pass password
this is default to router interface.. if do not work HARD RESET the router
see router reset on my sig below
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Discussion Stats
  • 1 reply
  • 19442 views
  • 0 kudos
  • 2 in conversation
Top Contributors
