Reply
Novice
iphone5 connects to WGT624 v3
I used this link posted by jmizoguchi
WGT624 v3 fix
I downgraded the firmware.
Original firmware version was 2.0.26_1.01
I downgraded to firmware version 2.0.10_1.01
This worked for my Netgear WGT624 v3
hope it helps for u 2
Luminary
Re: iphone5 connects to WGT624 v3
sounds like plan... enjoy it! Smiley Happy
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
I had upgraded my router due to the wireless going in and out, so I'm afraid if I downgrade the firmware, those problems will return. The 4S worked fine until 6.0 and 6.01 hasn't resolved anything either.
I am currently trying to fix my router (same as op's) so that my wifi will work w/ 4s. I downloaded the older firmware 2.0.21_1.01 to my desktop from the netgear download page. However when I try to upload the file in my router upgrade tab it says the file is not compatible or something like that. The file is actually a zip folder, and in the folder it has a internet file that has the instructions for install and another file that is fragmented. I don't know where to go from here to finish changing the firmware. Any assistance?
Discussion Stats
  • 3 replies
  • 2792 views
  • 0 kudos
  • 4 in conversation
Top Contributors
