Reply
losing internet and DND changing to 192.168.1.251
Hello,
We have the wndr4500 connected to BT Infinity Fibre.
Over the lat 2 days some wireless devices are losing internet and if I look the the IP details of the devices it says:
IP Address: 192.168.1.110
subnet: 255.255.255.0
router: 192.168.1.251
DND: 192.168.1.251
Th device is still connected to the internet but can't get internet. The only way to resolve this is a few re-connects to the network or give the device a static IP.
Any advice on what this could be?
Many thanks.
Re: losing internet and DND changing to 192.168.1.251
Sorry, where I've typed DND is meant to be DNS of course.
Prodigy
What would the ip details look like when they have internet?
Where are the devices getting these ip details from?
What device is at 192.168.1.251?
By the way - the device is still connected to the internet, but can't get internet. What exactly does that mean? If it's connected to the internet, how can it not get internet?
Give a man a fish, feed him for a day
Teach a man to fish, feed him for life.
hi, thanks for the reply.
if we take my iphone for example.
usually its:
ip 192.168.1.10
subnet 255.255.255.0
router 192.168.1.1
dns 192.168.1.1
but this sometimes comes up as :
ip 192.168.1.110
router 192.168.1.254
dns 192.168.1.254
The first set is correct, the 2nd set don't let me access internet.
Thanks,
Luminary
Likely you are connected to different wifi network
If your router IP is 192.168.1.1 then you should not see 192.168.1.251 or 19.168.1.254
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Hi, the SSID is still NETGEAR20. We live in a detached house and I can't see anyone else's network from our house.
This morning I restarted my router and deleted the network from my iphone.
Once the router was restarted, I scanned on my iPhone and found NETGEAR. I connected to this and the IP details were the incorrect set that doesn't allow me internet./
Luminary
Delete all wifi profile on PC and try again
If there is no other SSID near you or none then should have this issues
Makes sure pc is setup to obtain IP and DNS under network properties of wifi adapter
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
also the wifi signal is 3 bars. so can't be someone elses wifi. thanks.
Luminary
if you only shows your SSID ONLY then 3bars or 4bars would make less to be worried
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
hi, all profiles have been deleted and then re added. this then happens again.
I'm going to downgrade my router firmware tonight to see if that resolves it.
Luminary
This router will only dish out IP that is set in the router for DHCP
If router is 192.168.1.1 and DHCP range ex 192.168.1.2~192.168.1.254
Then router will only dish out 192.168.1.x with Gatewway/DNS 192.168.1.1
Unless you have some installation issues that causing TWO DHCP on your network.
Did you setup 4500 as access point and not as an router ?
Seems you have BT DHCP and 4500 DHCP where you are doing double NAT
You need to DETAIL the setup
Firmware is not as issues
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
REPLACE THE FIRMWARE WITH OPEN-WRT. AVAILABLE BOTH AT OPEN-WRT OR AT GARGOYLE. Eliminates these problems. Had mine fixed then the connection to the modem broke down. Think it's the connector. Have bought 4 netgear routers all have failed. Next will be something else, as I am not happy with netgear anymore. had to go back to the 3700 which also had these problems until I put open-wrt on it. Worked for awhile now it's taken to dropping from a connection speed of 65mbs to 19,16,3 for n apparent reason. So I am looking for a solution to this new problem now.
Discussion Stats
  • 11 replies
  • 7512 views
  • 0 kudos
  • 4 in conversation
Top Contributors
