Reply
netgear wgr614v9 wireless problem
hello. i have a wireless router wgr614v9 and i have problems with it since morning. hope i can find a solution here. i had problems with pppoe connection but i fixed now (update the firmware) but i still have a problem with wireless. when i'm connecting my phone (i don't know if it's important but i want to give you all info) samsung galaxy s2, everything is fine untill i'm going on internet. when i'm trying to acces a page router is restarting. so i can connect the phone but when update is comming up for a program or when i'm going on internet the router is restarting. a friend of mine said he have another router and have same situation and he fixed it by limiting the speed on wireless... i searched all settings from router but nothing about that.
what can i do?Smiley Sad
sorry for my bad english and thank you in advance
Luminary
Re: netgear wgr614v9 wireless problem
without using phone on wifi, can you use still any other wifi capable PC and has same issues?
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
i'm sorry because i didn't mention this important thing. answer is yes. i have my computer on LAN, my brother computer on wireless and my laptop on wireless, working smooth all together.
in this morning i had a surprise. last night i updated my phone but same problem. in this morning when i woke up, every station was off and ... wireless was on and i gave a try. IT WORKED. installing my programs from market, surfing internet. everything was normal till i turn on my computer. so i still have a problem when one of stations is on... if all of them are off, it's working.
i'm glad it's working, but i hope i can fix it and working with computers on.
Luminary
You never know how wifi will function!
At least you got it working
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
PROBLEM SOLVED!!!
much easier than i thought. CHANGE ADAPTOR. 12 V, 1 amp (original have same but change it). buy new one or take it from another electronics. it's working lan and wireless, even with my phone.
Luminary
weak power supply will do that..
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 5 replies
  • 2481 views
  • 0 kudos
  • 2 in conversation
Top Contributors
