Reply
Follower
resetting wireless router password
we are trying to add wireless devices but cannot remember our wireless network password. any ideas?
Apprentice
Re: resetting wireless router password
Open Internet Explorer and enter routerlogin.net in the Search Box (i.e. not the one for the search engine [e.g. Google]). It will take you to the GUI (Graphic User Interface) of the router. Enter admin as username and password as password (unless you have changed the default admin password). This will bring up the GUI and you should be able to see what the passphrase (network password) is.
If you did change the admin password and can't remember that too, then you don't have any alternative but to reset the router to factory defaults. You would have to re-enter all your config settings after. Use the downloads tab at the top of this page to get the manual(s) for your model router and you should be able to find the instructions on how to do this. Make sure to write down your passphrase and admin password and store it in a safe place so it doesn't happen again.
Apprentice
You will have to hard reset the router by pressing and holding the reset pin hole in back for 30 seconds. Release and then power cycle the router. Connect via wired computer to 192.168.1.1 now.
Apprentice
OH... wait... wireless password, not admin password. My bad.
Connect via wired computer to 192.168.1.1 username 'admin', password 'password' unless you changed it. Now navigate to your wireless settings and find your wireless password.
So I had a similar problem and had to do a hard reset. However, now my wireless network has no internet access, while the LAN is fine so I do have internet at home but my wireless is no longer working. The reason I even attempted to mess with this was due to my password being insanely complex. How can I get my wireless to work again?
Luminary
login the router and setup again. Reset will ERASE the wireless settings on older models.
Go to support.netgear.com and get your manual to the route will be handy.
This is basic question answer in the manual Smiley Happy
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
yea, sorry if I wasted your time. Apparently I am tired. I went back while I was waiting for a reply and ended up fixing it myself. I do appreciate your quick reply though. Have a great day Smiley Happy
Luminary
If this is wireless encrytion then log in the router
Get your manual at support.netgear.com
Manual have all your basic answer
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
How do we reset our wpn 824 v3 range max password using our new macbook pro, with firefox? we were using the symbol "&" and some of the new platforms do not recognize the symbol "&"
:confused:
Apprentice
Do not use those symbols. Just a a strong password with letters and numbers, that's all you need.
Luminary
:confused:
Apparently mine somehow got posted before you ..
"If this is wireless encrytion then log in the router
Manual have all your basic answer"
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Such as taping it to the bottom of the router, like I will be doing after I do a hard reset because I forgot my name/pass, lol Smiley TongueSmiley Very Happy:rolleyes:
I just spent literally 2 and a half days following the standard solution of trying to change a lost password by re-setting the router to factory conditions. I did it at least 8 times but nothing ever
worked. The trick was to keeing on pushing the pin into that tiny re-set button for at least 30 seconds and then giving it a minute to re-set itself. That is what my ISP suggested to me and it finally worked. There is no need for anyone to do any remote re-setting of your computer or paying for anyone's services to fix the problem. I stuck that pin in for at least 60 seconds and the problem was solved. The admin and 'password' password suddenly worked after 2 and a half days.
Good luck.
Luminary
Nice.
Router reset on my sig below will show you the few options you could have tried.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Apprentice
Babson wrote:
...trick was to keeing on pushing the pin into that tiny re-set button for at least 30 seconds...
...I stuck that pin in for at least 60 seconds and the problem was solved.
I have never had to hold the reset button for as long as 60 seconds, or for that matter, even 30 seconds. The router's user manual does say to hold the reset button for at least 5 seconds, but I've found that between 5 - 7 seconds is more than enough time for my router. Once the LEDs indicate the router is resetting I just release the button and wait on it to finish its thing - that's it.
Discussion Stats
  • 14 replies
  • 8826 views
  • 0 kudos
  • 8 in conversation
Top Contributors
