Reply
Novice
safe distance from router
Hi,
I am new to the forum and I hope I am in the right place.
My question is: what is the minimum safe distance between the router and your body.
Using NetGear vvg 2000.
Thanks,
Amnon
Luminary
Re: safe distance from router
FCC regulates ALL consumer is safe at any usage .
go to FCC for any question regarding to this..
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Wilensky , I have that router , and have checked it with the Cornet-ED85EX
Apprentice
Really? 1 meter away? You are safe at 2 inches, period. Don't ever worry about it.
Sabretooth - good luck .
By the way , have you ever checked the RF levels with a serious detector ?
Apprentice
As a I retired computer specialist and electrical engineer... don't worry about it.
Discussion Stats
  • 5 replies
  • 4827 views
  • 0 kudos
  • 4 in conversation
Top Contributors
