- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
After update won’t let me log in
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: After update won’t let me log in
I wish I didn’t update , can’t understand how an update is rolled without testing all elements beforehand
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Need help asap
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Genie app update doesn't allow you to log into network map. Any ideas???
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@Ricbrick88 wrote:
....after the update
What did you update? Your phone? One of the various genies? If so, which one? And which version?
The genie could be one of several things, the browser interface, a Windows or Mac application, or an Android/iThing app.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
My genie currently running a V3.1.70
Frameware version v2.08.07
Router model CG3000v2
The app connect to my wifi no issue the only issue is I can’t connect to the ‘network map’ anymore
The error login msg I get is
LOGIN FAILED
NETGEAR router was not found or not supported make sure you mobile device is not connected to the router’s guest network and that IPv6 is not enabled.
I mean the app was working fine nothing was change at all the only thing changed is the app got updated and I wish I didn’t
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Is it just the map that you cannot access? Or anything using the updated genie?
Just another user.
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
App doesn't work on iPhone or iPad after update. It worked then I updated and now it doesn't work. Someone at Netgear needs to get their arse into gear and sort this out a.s.a.p!!!!
its the app not working.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
So yes the answer to your question is the Map ONLY isn’t connecting or passing the error msg mentioned in my earlier post
I wish I didn’t block some of my devises and I wish I never used this app from the beginning.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have the same problem, today automatically update the Genie App, and now " Login Failed " with corret password ( only with app )
D7000 with last firmware .70 / iPhone 7 iOS 12.1.3 / Genie App 3.1.70.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@Charper wrote:
I’m having the same issue!!! Driving me crazy
This tells us nothing about what you actually see, what you are doing and if you have paid any attention to previous messages and tried the various suggestions.
Just another user.
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hey Michael, the App does not work correctly. You can not login into Network Map or any of the other functions. If you had read previous messages you would have understood. THE APP DOES NOT LET YOU LOG IN!!!!!!.
Tells us why this is and how to get over the problem or shut up!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
https://kb.netgear.com/000052286/NETGEAR-Community-Terms-Of-Service
Behave with civility and mutual respect.
Just another user.
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
With the last update of Genie App 3.1.72, the problem has not been resolved.
Always can't login with correct Username ( can't be changed ) / Password, in the local network with Genie App.
Until version 3.1.64 everything worked without problems, please fix it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Have checked -router firmware is up to date
Any sign of a new app release - looks like the fault - or other solution ??
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@PH69 wrote:
After iphone update, genie continues to not allow login.
If it was an iPhone update that killed the login and nothing has changed on the router then it is more likely to be the phone update that broke things. Look at that for fixes.
Just another user.
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Netgear needs to fix & release new version
