Reply
Highlighted
Follower
Default password not working?
My router was previously connect great it stopped working I deleted the device from my Netgear account in hopes to reconnect it. Now my default password isn’t working
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 4
Highlighted
Guru
Re: Default password not working?
What router do you have?
firmware on the router?
Deleting it from the account doesn't reset it. Did you try factory resetting it? Push and hold reset for 7-15 seconds while its powered on?
CAX80-> RBK53-> GS716v2-> TP-Link M9Plus
Message 2 of 4
Highlighted
In addition to the questions from @plemans, what does this have to do with the "Genie" that is the topic of this section?
The genie could be one of several things, the browser interface, a Windows or Mac program for a PC, or a mobile Android/iThing app. Netgear labels them all as genies. Which, if any, are you using?
Visit the support pages:
Support | NETGEAR
and feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 4
Highlighted
Guru
Not aware Netgear customers can remove devices from their Netgear accounts at all...
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 676 views
  • 0 kudos
  • 4 in conversation
Announcements
