- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Desktop Application Netgeargenie will not except any password attempts
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can access my router through the browswer no problem!!!
My modem was replaced due to faulty previous one.
When I launch the Desktop Appliacation Netgear Genie no password will work.
I have tried an previouse parental control password ... no good
Tried default and no good
Tried the one on the router ... no good
I have searched the hard drive trying to find where password might live to no avail.
I have a teenager in the house and trying to limit access and access times ....
Nothing works and the browser version does not give me parental control rights.
Dan
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Desktop Application Netgeargenie will not except any password attempts
Hi @doxa2u,
You can try to change the LPC (Live Parental Controls) password through the forgot password option if you have access to the email that you have registered. You can go to https://netgear.opendns.com/sign_in.php.
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
No go ... it is useless ... nothing works ... I can go on line through a browser and access the router. But I cannot access the parental controls through Genie app .. also I cannot access router settings through Genie App. I can go to the router, 192.168.1.1 and put in admin and default password .. no problem .. Genie app is useless cannot access through it
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @doxa2u,
1. What is the model number and firmware version of your device?
2. Please try using another device (Android, iOS, another computer).
3. Are you getting an error message? If yes, what is the error message?
4. Please try uninstalling and re-installing the app.
5. Have you tried resetting the router?
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dexter JB,
Yes indeed nothing has fixed the problem. I cannot log into the router through Genie.
I had a previous router and set up a unique password for parental controls.
The router was replaced and I can reach it through a browser however still cannot reach the parental controls.
If I could find were Genie hides the parental password I could reset it.
I have worked through the Terminal to dig under the hood to no avail.
Your help and follow up would be great
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @doxa2u,
1. The router password (also the password to login to Genie) is different from your LPC (Live Parental Control) password.
2. Are you referring to your LPC password?
3. If yes, have you tried using the forgot password option using the link below?
4. Did you sign up via OpenDNS? If yes, you can use the link below instead.
https://login.umbrella.com/?return_to=https://dashboard.umbrella.com/
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
User | Count |
2 | |
1 | |
1 | |
1 | |
1 |
