Orbi WiFi 7 RBE973
Reply
Finding IP addresses
Felicia86
Tutor
I have so many new IP addresses on my map on genie app since Christmas. How do I find out what device they belong too? Not able to pause them. Some I believe are not a computer nor phone.
Message 1 of 5
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: Finding IP addresses
Hi @Felicia86,
Welcome to the community!
You can try accessing the router UI and check on the attached devices list for a detailed look on the attached devices. You can also try changing the WiFI password if you are looking to connect only the devices that you use. The links below may help.
http://kb.netgear.com/app/answers/detail/a_id/980
http://kb.netgear.com/app/answers/detail/a_id/24096
Dexter
Community Team
Message 2 of 5
All Replies
DexterJB
NETGEAR Moderator
Hi @Felicia86,
Dexter
Community Team
Message 2 of 5
DexterJB
NETGEAR Moderator
Hi @Felicia86,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Message 3 of 5
Felicia86
Tutor
Yes, I am still having same problem. It never improved. I still have so many IP numbers shown that is connected to router. If you try to pause it wont and it wont allow you to change the name of it.
Message 4 of 5
DexterJB
NETGEAR Moderator
Hi @Felicia86,
I have sent you a message. Please check your inbox.
Dexter
Community Team
Message 5 of 5
Discussion stats
  • 4 replies
  • 2622 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
