Orbi WiFi 7 RBE973
Reply
Firmware 1.0.0.110._1.0.110
PEEL23
Tutor
Good evening
For some reason my router will not do this update. I have tried so many times and it just crashes.
Any suggestions please?
Model: DGN2200|Wireless-N 300 Modem Router
Message 1 of 4
Accepted Solutions
PEEL23
Tutor
Re: Firmware 1.0.0.110._1.0.110
Thank you both for your help.
Just by chance the update downloaded and installed correctly, after four months of trying on and off.
No idea why it worked this time, but it has worked.
Thank you for your help
Message 4 of 4
All Replies
schumaku
Guru
There are at least four different DGN2200 variants: DGN2200M, DGN2200v1, DGN2200v3, and DGN2200v4. The firmware imges are not freely exchangeable. Check your router product label (on the back) for the exact designation. Just in case: DGN2200-100xxx is v1, DGN2200-200xxx is v2, DGN2200-400xxx is v4. You need the exact matching firmware.
Message 2 of 4
Guru
There's 4 versions of the DGN2200. Which one do you have?
Define crashing. What exactly is happening, what error are you getting?
How are you attempting to do the update? app/manually/auto update?
If you downloaded the firmware, did you extract it prior to attempting install?
Here's the support site. make sure to select the correct version that you have.
https://www.netgear.com/support/product/DGN2200v1.aspx
Message 3 of 4
PEEL23
Tutor
Message 4 of 4
Discussion stats
  • 3 replies
  • 3749 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
