Reply
Firmware out of date
sagarsiddharth
Follower
The nighthawk app has been only showing "Firmware out of date; Visit routerlogin.net to update your routers firmware". I have visited router login.net many times but I didn't get the update which the nighthawk app has been looking for.
Model: C7800|Nighthawk X4S-AC3200 WiFi Cable Modem Router
Message 1 of 2
schumaku
Guru
Re: Firmware out of date
Visiting routerlogin.net will open the router Web UI only.
The firmware for your router model is available for download from https://netgear.com/support/ - type the product name e.g. R7800 to access the support section for your router model.
Permitting the guess (that's not the tagged C7800 - probably a R7800) is right, you will get guided to https://www.netgear.com/support/product/R7800.aspx so select [Downloads] and pick the current firmware for download, unpack the ZIP archive, then follow the guidelines as available in the fine manual or the current firmware release notes https://kb.netgear.com/000060527/R7800-Firmware-Version-1-0-2-62 on how to install the firmware file (R7800-V1.0.2.62.img is the file to be selected for upload, no double click or any other attempts to open or run it) to your device.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 5446 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
