Orbi WiFi 7 RBE973
Reply
Genie: 2.4.2 Device-based parental controls filtering keeps reverting back to "Default"
rtdeloatch
This problem still persists again. A previous fix was made, but I am having the same issue with Genie verison 2.4.22 for MAC, using the wireless N router. The deve-based parrental controls do not persists nor do their effects work on the specified device.
Message 1 of 4
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: Genie: 2.4.2 Device-based parental controls filtering keeps reverting back to "Default&q...
Hi @rtdeloatch,
1. What is the model number and firmware version of your device?
2. Please try setting the filtering level on another device (iOS, Android, another computer).
Dexter
Community Team
Message 2 of 4
All Replies
DexterJB
NETGEAR Moderator
Hi @rtdeloatch,
Dexter
Community Team
Message 2 of 4
DexterJB
NETGEAR Moderator
Hi @rtdeloatch,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Message 3 of 4
rtdeloatch
Hi I was able to change the settings using the Genie App, so I no longer have the problem (though I still can't change it on my MAC computer). So the problem is sort of resolved.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3974 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
