- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Genie - Parental Controls, cannot change settings on individual devices in the network map
- Mark as New
- Bookmark
- Subscribe
- Permalink
I set the default for parental controls to High during initial setup on the router. Then in the network map area, I tried to change the settings per user device, but when I click apply, the settings default back to the original "default level on router". How to I get these changes to take effect?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Genie - Parental Controls, cannot change settings on individual devices in the network map
Hi @shawn53913,
1. What is the model number and firmware version of your NETGEAR device?
2. What is the version of the NETGEAR Genie app/program that you are using?
3. Have you tried using another device (Android, iOS, another computer) to setup the per device filtering level?
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @shawn53913,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have the same problem.
I'm unable to change the settings for each device, neither from PC or from iPhone app.
iPhone app gives me at least an error message "PC_Remind_SetFailed".
The PC application "Netgear geni" version 2.4.36 on Windows 10 (which crashes all the time).
Model R7000 newest firmware 1.0.7.6.
Changes I have set earlier with an older firmware and older Geni app is still there, but changing any new devices fails.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Harangen,
1. Have you tried uninstalling and re-installing the app/program?
2. Have you tried resetting the router?
3. Was it working before?
4. Have you tried using another device (Android, another computer)?
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Past 10 devices and they will just keep reverting to default. You'll have to change a different device to default.
It's a really terrible set up.
I'm trying to figure out how to erase old devices that are no longer being used and that I don't have access to.
Very frustrating.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Jenhedr,
1. Do the unused/inactive devices still show up on the Network Map?
2. Have you tried uninstalling then re-installing the app/program?
3. Is the behavior the same no matter what device you use to individually set a filtering level?
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @skiddles6969,
1. What is the model number and firmware version of your device?
2. What error message are you getting?
3. Have you tried disabling and re-enabling Parental Controls?
4. Have you tried resetting the device?
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Product: R7000
Current Firmware: 1.0.5.70_1.1.91 (after resetting everything)
Previous Firmware: 1.0.7.6_1.1.99
No error messages, the device changes back to "default router" instead of none.
Yes, in all possible ways, including creating a new OpenDNS account.
Yes, I have uninstalled, installed, and reinstalled Netgear Geni on iphone, ipad, and two windows computers with the same issue.
I have changed/downgraded the firmware did not work either.
I have reset the router, and now I’m able to. This resultet in a lot of work with a household of 12 apple devices, 4 printers, 10+ computers.
I do not know/dear to upgrade the router with the latest firmware in case that messes things up again, after many hours of cleaning up.
I have also had this behavior earlier, but then it helped to use the iPad software.
I have used serveral different versions/revisions of the Netgear Geni, but some fails on Windows 10,
Cheers, Roger
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I am still experiencing the problem. And also encountered a different one in the last couple of nights.
Here's the scenario:
8 kids in the home, some with phones, some with kindles, some with android tablets, some just using laptops & tv's.
Because I cant control the individual devices, when a couple were naughty I simply just changed the password, which thankfully kicked everyone off the network. However, the next night, when I returned home, the password had reverted back to the original password. How does that happen?
I will get the model info etc. asap.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @shawn53913,
The only way for it to revert back is if the device is reset. Please keep us posted and the additional details and answers to my inquiry would help a lot.
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is this really true? Has someone at Netgear verified this? This would make the app pretty much useless.
- Mark as New
- Bookmark
- Subscribe
- Permalink
1. Set all the 'controlled' devices to be the - Default Level on Router.
2. Set all the parent devices to be custom controlled, by using ' Minimal' on the Genie and you'll be ok.
Provided you have all your controlled devices set up Default router, you can have up to 10 that have a custom control.
Sucks that Netgear has this limitation, we have a large number of devices in our house. Would be nice to have a bit more flexibility (more than 10) in the devices that don't need to be monitored or controlled.
N6900, bought from Costco if the router I'm using. Should be same as the N900.
Running Android Genie 3.1.28.
The router is at the latest firmware as well.
Cheers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The "more than 10" limit is not true. I've changed settings for more tha 10 devices. However, it seems that I cannot change the settings for certain specific devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So in order to resolve the filtering of the router and better simplify monitoring and blocking as well as usage, (Albeit I may have complicated things even more, but am looking for a more consolidated solution) here's what I did:
Purchased a second router, set it up as an access point only, and then made that WiFi the kids wifi network. I changed the main wifi password/SSID for the main router so only the parents used that router directly. Although this is a bit more expensive, it made monitoring and managing a little easier since I set a filter for the logs of the IP of the kids' access point. I added all the websites from those logs I didn't like to the access control list in the main router, and set the QoS for the Kid's AP to Medium, and set all the parents devices to High or Highest (that way kids don't hog all the bandwidth). When I go search the logs on the main router for the static IP of the Kids' router I can see all the sites and services they are attempting to use simplified, also in the console of the kids' router the wifi signal on their router is scheduled when to turn off & on. When I have time I'll probably end up buying a small business grade router that has more granularity for controls that can outright block specific URL's since keyword blocking isn't perfect...adding URL's in a console that understands the * command would make it so much easier. e.g. *website.com/* so it blocks everything from that specific site and it's sub sites.
