- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Genie login
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Genie login
Local mode ask me for a I'd and password
Admin
Password but doesn't work I can't login to settings how i can loging please help me
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Genie login
@Kikatazz_18 wrote:
I can't longing on my netgear model c6300
How are you doing this? Wifi? Wired LAN?
Remember, if you use wifi to get in you have to connect to the wifi before you can get into the controls for the device itself.
Where is this "local mode". The genie app?
By the way, you have posted your message in the section of this community given over to
Apps and Services.
he C6300 is a Cable Modem/Router
You might get better replies, and find other answers, over in the appropriate section:
Cable Modems & Routers
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Genie login
@Kikatazz_18 wrote:
Admin
Just in case: The username is admin (all lowercase), the default password is password (all lowercase, too).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Genie login
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Genie login
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Genie login
Hi,
@Raccoonacres wrote:
I can’t login either with the Genie app.
Android, iOS? Current version from Google Play or the App Store? Have seen some indications that newer App versions are indeed struggling, even if using the right password.
It won’t let me change my user name from the default “admin” when I try to login local ....
There is only one router local username - and this is admin. The same default admin username plus the default or your password set as when accessing the router using http://routerlogin.net/
and the remote login doesn’t work either. I have model WNDR4500v3.
Remote login must be enabled while on local access before it can be available.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Genie login
And how are you connecting to the device? Wifi or wired?
Remember, to get in with wifi you first need to join the wifi network. That has its own (different) password that is on the device's label.
When you have a wifi link then you can attack the user interface.
Just another user.
