Reply
How do I change the name of my wifi
Piper1213
Follower
Help I keep trying to change my WiFi name but it the app won’t even register my genie
Message 1 of 3
Guru
Re: How do I change the name of my wifi
Try logging in via the browser. If you're using a router go to routerlogin.net   default login is admin and default password is password
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 3
Tell us what the hardware is and you might get more detailed advice.
If you visit the support pages:
Support | NETGEAR
you can feed in the model number and find all the documentation for your hardware.
How do I change the WiFi password or security level on my NETGEAR router? | Answer | NETGEAR Support
How do I change my NETGEAR router password or network name (SSID)? | Answer | NETGEAR Support
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 879 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
