Orbi WiFi 7 RBE973
Reply
I am trying to portforward multiple ports on the same ip address
xRobert1016x
Follower
Hello, Last night I bought a 170 dollar router. I now need to forward some ports on the same ip address. I called netgear today because my 90 day complimentary free technical support expires in june. The lady who I was on the phone with charged me 80 dollars if I wanted to get my xbox to work. Of course, I just spent 170 dollars and I am not going to spend more, so I hung up. I know how to forward one port, but I can't forward any more ports. Please help!
List of ports that I need to forward:
3074 UDP/TCP
53 UDP/TCP
80 TCP
88 UDP
500 UDP
3544 UDP
4500 UDP
If there isn't any way that I can forward multiple ports, I have proof that my 90 day free technical support is still valid.
Screenshot here: https://gyazo.com/697a120cff60d6459237c222f380000b
Bottom right, shows that date is 3/4/17
Message 1 of 2
storm1985
Prodigy
Re: I am trying to portforward multiple ports on the same ip address
> regarding with the technical support, call them again and be ready with the proof of purchase
also login to my.netgear.com to double check your product support warranty
> regarding with adding multiple ports in the same IP address. The answer is YES. But you have to add the ports one by one.
If port isnt listed on the service name then you have to manually add a custom service to porward the port.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 10925 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
