Orbi WiFi 7 RBE973
Reply
Ios10 + genie
Rands100
Ios10 + genie
Since updating my iPhone to ios10 netgear genie doesn't work.
Any ideas?
Thanks
Message 1 of 17
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: Ios10 + genie
Hi @Rands100,
Thank you for responding. The remote login through the Genie app feature is currently only supported by the following router models:
    R6250
    R6400
    R6700
    R6900
    R7000
    R7300DST
    R7800
    R7900
    R8000
    R8300
    R8500
    R9000
You may refer to the article linked below.
http://kb.netgear.com/app/answers/detail/a_id/26109
Dexter
Community Team
Message 17 of 17
All Replies
DexterJB
NETGEAR Moderator
Re: Ios10 + genie
Hi @Rands100,
Have you tried uninstalling and re-installing the app?
Dexter
Community Team
Message 2 of 17
Alexsanders
Re: Ios10 + genie
Rands, are you getting lines where numbers used to appear inside the app or will it just not load at all? I'm having a similar issue if it's the lines.
Message 3 of 17
Rands100
Re: Ios10 + genie
I uninstalled it then reinstalled it and I can now get into it but there are lines where numbers should be.
Message 4 of 17
Alexsanders
Re: Ios10 + genie
Exact same issue on my end. Latest iOS release of Genie app on iPhone 5S running iOS 10. Have a WNDR4000 router with the latest firmware. I think it's a Genie issue though, not router related. Hoping the Netgear Genie devs are working on a fix?
Message 5 of 17
DexterJB
NETGEAR Moderator
Re: Ios10 + genie
Hi @Alexsanders and @Rands100,
The fix for the numbers issue will be on the next release. Please make sure you keep the app updated.
Dexter
Community Team
Message 6 of 17
Rumarch64
Re: Ios10 + genie
Iohon6 IOS 10;Genie; DGN2200v4: appena aggiornato Genie è stato impossibile effettuare login per qualsiasi tipo di operazione. Prego risolvere, Grazie
Message 7 of 17
Alexsanders
Re: Ios10 + genie
NETGEAR sta lavorando su una correzione a quanto pare. continuate a controllare l'App Store per un aggiornamento. utilizzando Google Translate così scusi il mio cattivo italiano.
Message 8 of 17
DexterJB
NETGEAR Moderator
Re: Ios10 + genie
Hi @Rumarch64,
Please try uninstalling and reinstalling the app and check if you are able to login through the app.
Dexter
Community Team
Message 9 of 17
Rumarch64
Re: Ios10 + genie
Power off/on on the router: login ok! Thanks
Message 10 of 17
DexterJB
NETGEAR Moderator
Re: Ios10 + genie
Hi @Rumarch64,
Thank you for the confirmation.
Dexter
Community Team
Message 11 of 17
Alexsanders
Re: Ios10 + genie
App is fixed. Version 2.4.34 with iOS 10.0.2 working perfectly. Thank you for a quick fix and excellent support. Just reaffirms why I won't buy a router from any other vendor or have for the past 12 years.
Message 12 of 17
Rands100
Re: Ios10 + genie
The problem I have now is that I can't get into the genie app remotely from my phone. I can log in okay when on the wireless network but as soon as I'm away from that and I try to login it says to connect to wireless network.
If I put the remote access IP address in the browser it works okay that way. Just not through the app.
Richard
Message 13 of 17
Alexsanders
Re: Ios10 + genie
My guess is that they did this for security reasons. Tunelling in from an external IP is always risky. Maybe they can implement some type of vpn with the Genie app? I'm no network expert but this problem has been with this app since I first started using it maybe 5 years ago.
Message 14 of 17
DexterJB
NETGEAR Moderator
Re: Ios10 + genie
Hi @Rands100,
1. What is the model number and firmware version of your device?
2. Have you tried un-registering and doing the registration for remote login again?
3. Does the issue persist on all your devices?
Dexter
Community Team
Message 15 of 17
Rands100
Re: Ios10 + genie
Hi Dexter,
1. Model no. is WNDR3700v4
Firmware is 1.0.2.78WW
2. I've tried registering for remote access again
3. It does the same on all my devices.
Richard
Message 16 of 17
DexterJB
NETGEAR Moderator
Re: Ios10 + genie
Hi @Rands100,
    R6250
    R6400
    R6700
    R6900
    R7000
    R7300DST
    R7800
    R7900
    R8000
    R8300
    R8500
    R9000
Dexter
Community Team
Message 17 of 17
Top Contributors
Discussion stats
  • 16 replies
  • 6989 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
