Orbi WiFi 7 RBE973
Reply
My Parent Control got disable after firmware update. R7500
peaceful
Follower
After I update my router firmware, I lost parent control option. I have a Nighthawk X4 AC2350. The Router model is R7500v2 and the current firmware version V1.0.3.26.
When I click on Parental Control in the Netgear Genie, I got the error message below:
Checking Router Firmware
We're making sure you have firmware that supports Like Parental Controls.
It looks like you might not be connecting to the Internet through a supported NETGEAR router. Please make sure your computer is connected to you NETGEAR router via a wireless or Ethernet connection and try again. If this problem persists, turn off you router and turn it back on, wait until LEDs are lit and try again. For further assistance visit http://netgear.opendns.com/support.
I have tried both connecting to the router wire and wireless and none work. My NETGEAR router connects to a AT&T U-Verse. And it has been work fine before I updated the new firm ware.
Please help!
Model: R7500|Nighthawk X4 AC2350 Smart WiFi Router
Message 1 of 3
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: My Parent Control got disable after firmware update. R7500
Hi @peaceful,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Message 3 of 3
All Replies
DexterJB
NETGEAR Moderator
Hi @peaceful,
Welcome to the community!
Please make sure you do a factory reset after updating the firmware. This link may help for the steps.
Dexter
Community Team
Message 2 of 3
DexterJB
NETGEAR Moderator
Hi @peaceful,
Dexter
Community Team
Message 3 of 3
Discussion stats
  • 2 replies
  • 2726 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
