Orbi WiFi 7 RBE973
Reply
Netgear Genie Authentication Problem
Jonnoza
When logging via a browser I can access my router. If I try via iPhone or iPad genie app I get th message "login failed. Please enter in the correct Admi password".  Password gives access via the browser but not the app. I can even access the router via the iPhone and IPad browsers but not the genie app
Message 1 of 6
Accepted Solutions
Jonnoza
Re: Netgear Genie Authentication Problem
With the new App update to version 2.4.38 the problem has been resolved.
Thank you
Message 5 of 6
All Replies
DexterJB
NETGEAR Moderator
Hi @Jonnoza,
Please try uninstalling and reinstalling the app. If the issue persists, please reboot the router and try logging in through the app again.
Dexter
Community Team
Message 2 of 6
Jonnoza
Thank you
Have done all of the above. Waited for a Genie app update, hoping this would solve the problem. Factory reset of router.
I can access the router with PC, iPad, iPhone using a web browser. But the Genie app will not accept the same password that is used to access the router using a browser.
Message 3 of 6
DexterJB
NETGEAR Moderator
Hi @Jonnoza,
Thank you for responding. We are currently investigating this. Please make sure you keep the app up to date for possible fixes.
Dexter
Community Team
Message 4 of 6
Jonnoza
Thank you
Message 5 of 6
DexterJB
NETGEAR Moderator
Hi @Jonnoza,
Thank you for the confirmation.
Dexter
Community Team
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 6903 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
