Orbi WiFi 7 RBE973
Reply
Netgear Genie and ms surface
ttfo
Tutor
I cannot get genie to run in normal or full screen mode on my MS Surface. It works fine on my other laptops.
The Genie app displays a small screen.
Message 1 of 3
Accepted Solutions
schumaku
Guru
Re: Netgear Genie and ms surface
This is caused by the screen/display scaling going beyond of 1.5.
https://support.microsoft.com/en-us/help/15078 does help on how to change the High DPI mode for the seleced program e.g. to Application mode.
Message 2 of 3
All Replies
schumaku
Guru
Message 2 of 3
ttfo
Tutor
Thanks, that worked. I tried "application" first, did not work
Used "system" that worked.
Message 3 of 3
Discussion stats
  • 2 replies
  • 1932 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
