Orbi WiFi 7 RBE973
Reply
Netgear Genie
velocci
Novice
Netgear Genie
Hi all, I installed the netgear genie app. I notice in the Internet tab, if you look at the bottom you see a slider that goes upto 20Mbps and button for "High Traffic Threshold. What are these for exactly? is it to limit the speed of transfers when there is high network transfer? if I want the maximum transfer speed, should I have this box unchecked?
Message 1 of 6
onebyside
Novice
Re: Netgear Genie
I would simply try it and see if you get the desired result
Message 2 of 6
velocci
Novice
Re: Netgear Genie
I didn't notice any difference in the transfer rate when I played around with that feature. Is there a manual for this software?
Message 3 of 6
croisan
Re: Netgear Genie
If you search Google for Netgear Genie, you will find the software download site. There is also a link for the user manual. This will get you there a little faster.
http://www.netgear.com/landing/en-us/netgear-genie.aspx
Message 4 of 6
NeedHelpToo
Re: Netgear Genie
FYI the manual doesn't tell you what the "high threshold" checkbox does.... does anyone know?
Message 5 of 6
DexterJB
NETGEAR Moderator
Re: Netgear Genie
Hi @NeedHelpToo,
The "High Traffic Threshold" check box will enable the NETGEAR Genie to monitor and notify you whenever it reaches the slider value of Internet traffic that you have set for the upload and/or download.
Dexter
Community Team
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 23445 views
  • 6 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
