- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
No internet connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: No internet connection
1. what modem/gateway is the router connecting to?
2. is this a new install? for the modem or router?
3. what firmware is on the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
the label doesn't have a model number on it.
Was the modem activated?
if so, try this.
Disconnect everything from both modem and router (even coax from modem).
Power them both off and leave them for 5 minutes.
Reconnect coax back to the modem and power it on.
give it a couple minutes to fully boot.
connect lan cable from modem to wan port on router.
boot up router and give it a couple minutes to fully boot.
then try setup on the router.
If it fails, tell me where in the process it fails.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
did you go through setup on the router?
That just indicates the router detected a connection to the modem but it isn't setup
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What actual model modem is it?
Have you replaced the cable from router---modem?
Is the modem provisioned by your ISP and active?
If the netgear is new, you should have the 90 days of free support.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
